Ok so once you have Unziped the file you downloaded, to a folder, with winrar. You need to install Alcohol, once you get that working...do go to options, the tree will come up, look down the tree to recording, go in to recording...check the "Book type" radio button, (im using very little words as not to confuse you) After close that out..
.Open the file where you Unziped your CD you downloaded (remember once you download it, you need to UNZIP IT TO A FILE!! and it's 7.XX gig!! you need room!!)...If you have done things right so far, the files you unziped will now be with and red boxes, with the file extentions in the in red. (ex. .MDS in red)
open burning program Alcohol,
Drag anyone of the files, there will be two!!...it does not matter!!!!!!!!!!!!!!!!! To the wide open box to the right of the selection pane. dont worrie about any thing.
Right click it the file in the wondow you just draged!! (again in alcohol)..select image burning wizard...Once you do that everything else will be done...Hit next...Change the speed option to slow as you can go...and hit start...close everything else down!! don't use your computer at this time, unless you got a core two duo, like me!! lol or a mac! and then if you need to know how to do this, you should not own a mac! lol J?K all..
This is the stupid easy part!!...wait for 40 min!! and then your done..
I used HP DL R+ media... my navi will be hook up tomarrow, i don't have my GPS yet, but this should still boot?
Any questions....i'll try to help, but really this is easy...If you cant figure it out, have someone do it, or bur the disc! Or read instructions! HAVE FAITH!!
