After use Hackmode autoinstall 2.2 carradio Pioneer F920Bt show "There is no applicable program". This carradio can go to testmode menu with testmode.key on the micro-CD card. But I don't know how to put the firmware for repair it. Please help. Thanks.
F920BT how to fix "There is no applicable program"
Please can anyone help?
Victim #3,428 of the horrible Hackmode 2.21. There's a thread on how to undo its damage. Search.
Well I don't own a F920BT so I don't exacly know, but Lyverby is referring to this:
Undo Codi's Hackmode
http://avic411.com/index.php?/topic/36854-undo-condis-hack-mode/?hl=hackmode
I tried to do everything step by step as described in the link. It does not help. I took the file AV.EXE from original firmware for my AVIC F920BT and put it to USER\PRG0\APL\ directory. This is not to help too. Whan can to do? Lyverby, help please! Thanks!
Maybe should to copy the entire directory APL from the firmware instead of the APL which is in AVIK?
It also did not help ![]()
Sorry, I don't know how to help you. Many people have damaged their unit because of this hack and I've requested many times that the administrators put a huge red blinking "DANGER" notice next to it, but they don't seem to care.
When I started to mess around the hacking my x930BT and saw what HackMode does, I didn't even try it because I knew how dangerous it was. Unfortunately, not everyone does.
How to possible to make update this Avic from this state with the original firmware from the support?
Hi everyone.
So,do you have still this problem with "There is no applicable program"? If yes, thats whats to do:
1.Take micro sd card and copy on it with testmode: PRG1 (folder from radio), Av.exe (file from update - i take from 2013) and testmode.
2.Delete old PRG0 folder from radio (with testmode).
3.Change name of folder PRG1 on PRG0 (on your micro sd card).
4.Copy Av.exe file to PRG0\APL (on sd card or direct to radio - with testmode)
5.Copy PRG0 to radio with testmode.
Ready ![]()
go into test mode handles user file and then delete all do back up and copy everything in the file and then restart key user on position
