I just got the "there is no applicable program" screen after running Condi's hackmode 2.x. After doing a search, I didn't find a concise means of reverting back so I disected the installer and came up with the following:
Using Super TestMode
As with any mods to your AVIC, the following is at your own risk.
I was successful doing the following on my X930BT (updated to X940BT)
Step 1
From a PC create 2 directories on a SD card:
PRG0 and PRG1
Copy the Super Testmode.KEY to the root of the SD card
Step 2
With the SD card in your AVIC boot into Testmode
VERIFY THAT THE FOLLOWING FILE EXISTS: USER\PRG0\APL\AV1.EXE
If it doesn't, do not continue!
COPY USER\PRG0\APL\AV1.EXE and then paste into the PRG0 directory on the SD card
If the following files exist:
COPY USER\PRGx.FLG to the SD card
COPY USER\PRG1\APL\AV1.EXE and then paste into the PRG1 directory on the SD card
Turn off your AVIC and take the SD card back to your PC
Step 3
From your PC
Rename PRG0\AV1.EXE to AV.EXE
Rename PRGx.FLG to PRG.FLG
Rename the PRG1\AV1.EXE files to AV.EXE
Step 4
DELETE the following files on your AVIC
USER\PRG0\APL\AV.EXE
USER\PRG1\APL\AV.EXE
USER\PRG0\APL\AV.MSCR
USER\PRG0\APL\COMMCTR1.DLL
USER\PRG0\APL\CORED1.DLL
USER\PRG0\APL\KILLPROC.EXE
USER\PRG0\APL\MORTSCRIPT.EXE
USER\PRG0\APL\TOOLHEL1.DLL
COPY the following files from the SD card to your AVIC
SD\PRG0.AV.EXE to USER\PRG0\APL\AV.EXE
SD\PRG.FLG to USER\PRG.FLG
SD\PRG1.AV.EXE to USER\PRG1\APL\AV.EXE
If you have followed the above exactly, your AVIC should be back to the way it was before the HACKMODE
