Undo Condi's Hack Mode
By atlcarl69 · May 29, 2013in Hacks/Mods💬 44 posts👁️ 30,989 views
Page 2 of 2
Posted Dec 04, 2014 · 04:58 UTC#26
I just got the "there is no applicable program" screen after running Condi's hackmode 2.x. After doing a search, I didn't find a concise means of reverting back so I disected the installer and came up with the following:
Using Super TestMode
As with any mods to your AVIC, the following is at your own risk.
I was successful doing the following on my X930BT (updated to X940BT)
Step 1
From a PC create 2 directories on a SD card:
PRG0 and PRG1
Copy the Super Testmode.KEY to the root of the SD card
Step 2
With the SD card in your AVIC boot into Testmode
VERIFY THAT THE FOLLOWING FILE EXISTS: USER\PRG0\APL\AV1.EXE
If it doesn't, do not continue!
COPY USER\PRG0\APL\AV1.EXE and then paste into the PRG0 directory on the SD card
If the following files exist:
COPY USER\PRGx.FLG to the SD card
COPY USER\PRG1\APL\AV1.EXE and then paste into the PRG1 directory on the SD card
Turn off your AVIC and take the SD card back to your PC
Step 3
From your PC
Rename PRG0\AV1.EXE to AV.EXE
Rename PRGx.FLG to PRG.FLG
Rename the PRG1\AV1.EXE files to AV.EXE
Step 4
DELETE the following files on your AVIC
USER\PRG0\APL\AV.EXE
USER\PRG1\APL\AV.EXE
USER\PRG0\APL\AV.MSCR
USER\PRG0\APL\COMMCTR1.DLL
USER\PRG0\APL\CORED1.DLL
USER\PRG0\APL\KILLPROC.EXE
USER\PRG0\APL\MORTSCRIPT.EXE
USER\PRG0\APL\TOOLHEL1.DLL
COPY the following files from the SD card to your AVIC
SD\PRG0.AV.EXE to USER\PRG0\APL\AV.EXE
SD\PRG.FLG to USER\PRG.FLG
SD\PRG1.AV.EXE to USER\PRG1\APL\AV.EXE
If you have followed the above exactly, your AVIC should be back to the way it was before the HACKMODE
I did everything step by step and still wont past the first screen I need help please
Posted Feb 18, 2015 · 21:21 UTC#27
hello i've just buy an f930bt and the owner forgot the password, so i tried to found it with hackmode 2.21 but now i have just the first screen on my unit somebody can help me please, i'm from belgium
Posted Feb 21, 2015 · 08:15 UTC#28
After install of Condi's Hack Mode, my f30bt didn't want to boot anymore.
Here is a modified script for uninstalling this hackmode.
Put these files on an usb or sd drive and start your device. :)
gweny
HACKMODE_REMOVAL.rar
Edited Feb 21, 2015 by gweny
Posted Feb 28, 2015 · 14:17 UTC#29
thank you i remove it but my unit still not running just the screen image
Posted Mar 13, 2015 · 06:34 UTC#30
gweny
gweny - Man, thanks so much for posting this fix!!! Worked like a charm on Condi's hack mode which I had to use to recover my password in a recent re-install of my x930bt....   Struggled with it for a while and I am not a computer dummy :x , but there is something about Win CE that makes me say brrrrr! Owe you, dude!
Posted Apr 08, 2015 · 21:36 UTC#31
I have AVIC-X9310BT unit in subaru BRz. While trying to sofmod parking brake bypass accidently delete all the files under USER folder.
can someone please help give direction to fix the issue or if someone has USER folder backup from same unit. Pls Pls share.....
Unit is bricked right now...
Posted Apr 08, 2015 · 23:02 UTC#32
Here is my backup of v3 before I updated to v5.  Hope it helps.
http://www.mybyteideas.com/x9310bt/
Edited Jul 25, 2015 by BlakeStone
Posted Apr 12, 2015 · 11:33 UTC#33
PLEASE HELP
I have exactly the same probleme than gweny on AVIC F20BT
After install of Condi's Hack Mode 2.1 my f30bt didn't want to boot anymore.
I just remove everythibg with zip.gif  HACKMODE_REMOVAL.rar but it s exactly the samething :idea:
The only screan i have in "THERE IS NO APPLICABLE PROGRAM"
what can i do for restore ?
Posted Apr 12, 2015 · 13:41 UTC#35
thanks , i ll try and let you know !!!!
Posted Apr 12, 2015 · 18:02 UTC#36
I finaly resolve my problme !!!
===> The only screan i have in "THERE IS NO APPLICABLE PROGRAM" <========
Big thanks to BlakeStone
What i do it remove all my USER FILE with SUPER TESTMODE
and i put the one of BlakeStone => X9310BT USER Folder
eveything is there => http://home.comcast....nful75/x9310bt/
after a REBOOT everything coming back :-)
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
so before doing anything ALWAYS MAKE A SAVE OF YOUR USER FILE
Posted Nov 13, 2015 · 18:00 UTC#37
Hello,
I am one of those stupid guys, who tried Condis Hack. I read hours and hours in this forum, I spent more than 8 hours by trying everything.
I used the "HACKMODE_REMOVAL". It runs (seems successfully) but after that it does no reboot.
I tried to change AV.exe, tried to change user-folder... copy is possible, but no PASTE.
I used the SUPERTESTMODE from 26th of september 2012, which one PIONARA suggests. But I can not write / paste! Damn.
What else can I do? Maybe I could try an update? But I have no downloaded updates. Maybe anyone can give me a working downloadlink for updating the firmware of my device.
AVIC F930BT ist my model.
Thanks a lot for your help!
Posted Nov 15, 2015 · 17:02 UTC#38
Your best bet is to to try an update using the latest HERE.
Posted Dec 06, 2015 · 19:27 UTC#39
ekki did you manage to get it working again?
I've been through allsorts of pain with my F10BT with that error for months and finally got it working again today :mrgreen:
I might be able to help you
Posted Apr 08, 2016 · 17:28 UTC#40
Hi !!
I did manage to restore my F930BT device. Thank you Lyverbe for your av.exe file, and also thanks Condi's Hackmode v. 2.21.
I see that inside Condi's Hackmode v. 2.21 the file "av.exe" is placed in two different file. So, I replace av.exe files  from "CONDIHACK\DATA - av.exe" and from "CONDIHACK\INSTALLER - av.exe with file downloaded from Lyverbe  dropbox. After this i just run again my updated  Condi's Hackmode v. 2.2i and the system start normaly .... I hope this method will help you !!!!! I add my updated condi's hack file ... if enebody needed ... :) Good Luck !!!
condi hack update vali.rar
Edited Apr 08, 2016 by valentin17
Posted Sep 07, 2016 · 22:39 UTC#41
Hi All,
IM so Stupid to screwed up my avic f840-bt with the hackmode and testmode i was so stupid to remove all folders about the user folder in testmode
the unit now has first the blue screen after that you see a black screen nothing is working anymore also Hackmode is not working anymore and gives a black screen,
im only able to come in TESTMODE does anyone knows how i can fixed it ? or does anyone maybe have a backup of the user folder containing PRG0 PRG1 SETUP, and the rest ?
I really appreciated help i playing already for 5 hours with the unit and not able to fix it :(
Edited Sep 07, 2016 by mauricee93
Posted Oct 22, 2016 · 06:32 UTC#42
Hi I have a X930BT I installed the hackmode. Didnt delete or change anything.
Then a day later went to use hackmode again so DL the files again and it reinstalled condi now my unit is stuck on the pioneer screen. Any way to fix?
Posted Nov 08, 2016 · 20:22 UTC#43
gweny
Thank you buddy, you save my AVIC.
Posted Feb 14, 2019 · 14:34 UTC#44
Hello,
I too lost my original Av.exe because of Hackmode v. 2.21 from Condi. I have a F930BT avic. which is frozen on the first screen (Navgate)
@Lyverbe can I use your AV.exe file for my avi F930BT, If so please send it to me.
Best regard
Page 2 of 2
