NEX 4100 Movie Bypass
By Vowens · Jul 03, 2015in NEX Series💬 12 posts👁️ 3,849 views
Posted Jul 03, 2015 · 03:44 UTC#1
How can I bypass the restriction on watching a movie while driving?
Posted Jul 03, 2015 · 13:23 UTC#3
DO NOT BUY BYPASS HARDWARE!!!!! Connect the parking brake wire correctly.
The bypass is done with software only on current NEX units. Follow the instructions, skipping step 1, in the bypass sticky thread at the top of the forum.
http://avic411.com/index.php?/topic/38589-official-avic-nex-bypass-avic-units-only/
Edited Jul 03, 2015 by 493008
Posted Jul 03, 2015 · 13:26 UTC#4
We're talking about the "AVH" 4100 here. Get the microBypass.
Posted Jul 03, 2015 · 15:08 UTC#5
The OP says "NEX 4100 Movie Bypass", so, yes, it's a software only bypass, involving these simple steps:
[step 1 (parking brake wire) not needed]
Step 2 turn power on, push main menu button (bottom center)
Step 3 touch AV icon (towards bottom center)
Step 4 on AV icon screen touch off button (towards bottom)
Step 5 touch quadrant 4 (half inch in and half inch up from left lower corner of touch screen) hold your finger there for about 10-12 seconds. "set on" icon will appear that means you are done.
Edited Jul 03, 2015 by herbert68
Posted Jul 03, 2015 · 15:37 UTC#6
So you have a 4100 and this worked for you? My understanding was this only works on "AVIC" units.
In any event, I installed the micro bypass on my 4100 and it works fine.
Posted Jul 03, 2015 · 16:28 UTC#7
My understanding is that this software solution DOES NOT work on AVH units. I have an AVH unit and it didn't work. I bought the bypass and it works perfectly.
Posted Jul 03, 2015 · 18:33 UTC#8
Maybe I'm misunderstanding the OP who posted in the NEX Series forum "NEX 4100 Movie Bypass", which makes me assume he/she talks about a 4100NEX. This software bypass definitely works on this unit.
ScottinPollock, cajunreb What makes you assume this is about an AVH unit?
Posted Jul 03, 2015 · 19:15 UTC#9
The 4100 is an AVH, and it does need the bypass, read the thread. Only AVIC models with navigation only. I repeat get the bypass and be done with it. they are all NEX, but they are not all AVIC.  The sticky post explicitly says AVIC ONLY.
Edited Jul 03, 2015 by joemamma1954
Posted Jul 03, 2015 · 19:19 UTC#10
The NEX models are
AVIC 5100NEX, AVIC 6100 NEX, AVIC 7100 NEX, AVIC 8100 NEX
AVH 4100 NEX.
The 4100 does not have Navigation, without the AVIC U-260 add on.
Posted Jul 03, 2015 · 20:25 UTC#11
The NEX models are
AVH 4100 NEX.
Thank you joemamma1954, now I understand.
Posted Aug 09, 2015 · 04:54 UTC#12
Pac Tr7 and a relay will do the trick. Just need to program the TR7 for the extended boot up time. Do it all the time
