thanks!
2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
Hi! I need VERINFO.DAT for f920bt, someone has it??
Please I need VERINFO.DAT because I tried only changing CARDINFO and 98% gives me error. Urgent help!
Maybe a strange question, but do i have to put the originial sd back in the 930 after updating? What is it used for?
If you bought your 930 aftermarket, then somebody gave you a free sd card. It is likely not needed unless there's something wrong with your unit that requires the sd card to boot it into operation.
If your unit works without it, you are good to go with a free sd card.
Please can any one post the Romanian TTS voice coming with the last update(2015), is about 125Kb. I will like to compare with the voice that I already have that work with the same engine nua_v5. I was able to extract some how the last update(2015) but I am confuse because the voice that I extracted are in a strange format not a zip file. Lock like this EU090TTS.RUM and I am not sure If this file is encrypted or It need to be like this. If any one can help or give me some hints... please do.
Thank you.
After more research I find that the structure of the voice is correct.
Any one know a way to parse this type of files to get the resources?...
I updated (Eu 2015 map) my f9220bt unit. It works fine.
there are lots of quest. about 9220 update: pls use this link (http://bit.ly/1Xp3qws) to download sd card files. unrar pass: 42E6FF89843D8BA94C4B2FFBA6624
After formatting (fat 32) the 4+gb sd card (i dont know whether it is compulsary or not) copy the downloaded sd card files to your sd card.
download the f9220 compatible cardinfo.cif modded file from this link
http://s000.tinyupload.com/index.php?file_id=96464814939960980540
copy it to sd card root and replace cardinfo.cif file.
that is all.
PLUG YOUR ​​SD CARD TO YOUR F9220 UNIT
TH​AN INST.PROCESS WILL TAKE 25 MIN.
ready to ​answer your further question.
Need this update for the AVIC-F70DAB ![]()
Good evening,
will be that this updating and compatible with Pioneer Avic F50BT?
Thanks.
Question about upgrade my Avic-F940BT (Eu 2015 map)
download files on sd card:
FIRMWARE
UPDATE
CARDINFO.cif modified on 13-4-2015 10:06 (do I have to change this file or leave it en start upgrade ?)
I'ts the first time i do this, and want be sure that I am doing the right thing in one step.
on 940bt, you can upgrade without modifying anything...
Updated from Platform version: 4.000 to 6.000 in 25 min.
Thanks a lot pmc2
It works flawlessly on my F920BT
Enclosed cardinfo.cif zipped
I have a avic F10bt that is upgraded to software version F20BT 2013.
I got the files and the cardinfo.cif and VERINFO for older models. Is that enough to install the update. Or do I need the dutch TTS files?
Just did the update and it worked for me.....! In dutch...
I have avic F20bt, I already updated with 2013 maps downloaded here, with this files it doesn't boot from sd
What files are good for me?
Just pickup the files a few page back, place the cardinfo in the root and verinfo in the update.
It works! Thanks a lot!
It works on my F9310. Thanks!
But i have this problem: On the screen it appears a message „Restarting the sistem because of a tuner errorâ€,then „OKâ€. I press ok but appears again. What should i do? (at least not to see this message anymore).
HEEELP PLEASE !
Is this possible on the AVIC-F70DAB?
Thank you.
Hallo,
problemlos und wie geschmiert das European 2015 Map Update auf meinem F940BT von 4.ooo auf 6.000 installiert und anschließend noch Bluetooth 3.32.
Da ich eigentlich nur die Südamerika-Karte auf mein Navi installieren und habe daher tage-, wochen- ja monatelang hier im Forum gelesen und immer wieder gelesen, aber keine Antwort gefunden.
Heute hat mich wohl der Teufel geritten und ich habe, obwohl ich dieses Update nicht brauche, es installiert und ich muss sagen: die Mitwirkenden an diesem Update kann man gar nicht genug loben
für ihre phantastische Arbeit in ihrer Freizeit.
Ich möchte daher eine Spende per PayPal machen, weis aber leider nicht an welche E-Mail Adresse oder auf welches Konto.(Vielleicht mir auf [email protected] mitteilen)
(Vielleicht erfahre ich doch noch, wie ich eine Südamerika-Karte auf mein F940Bt bekomme. Ich weis aber schon, das Pioneer neuerdings TomTom Karten verwendet)
Wünsche allen hier im Forum "Frohe Weihnachten" und ein gutes "Neues Jahr"
Uli aus Chile
Dear,
someone can upload the file one more time?
Andrea
Sehr geehrte Unbekannte,
versuche die Links im Profil PMC2 Nr. 627.
Den Erstellern nochmals Vielen Dank
ulito44
Some one who can help me to get firmware updated for F930bt ?
and speedcams?
Hello
Can someone put a link with the files that I need to update the maps for a Pioneer f930 bt? The old links don't work anymore.
Thank you very much ![]()
