x930bt ipod cable not working with 5.0 firmware
By njseadooer · Sep 14, 2015in Problems/Troubleshooting💬 6 posts👁️ 3,054 views
Posted Sep 14, 2015 · 12:47 UTC#1
I recently upgraded my x930bt to the 2013 maps
After doing so it looks like my ipod cable no longer works for anything but charging.  When I attach my ipod, the radio does not detect it and switch to ipod mode/start playing music like it used to.  If I manually try to play audio from the ipod, nothing comes out the radio.
AV1 is set to IPOD and AppMode is set to wired.
Does anyone have any suggestions?  If the wire is no longer going to work, is it possible to downgrade the firmware?
Thanks for any help!
Posted Oct 13, 2015 · 22:52 UTC#2
I'm having the same problem . . . have you found out anything to solve this problem?
Posted Oct 28, 2015 · 14:37 UTC#3
No, I am at a complete loss on this one.
Does anyone have any idea how to roll back the firmware and get rid of 5.0 to see if that fixes my issue?
Thanks,
Craig
Posted Dec 14, 2015 · 18:32 UTC#4
Did anyone find a fix for this?
Posted Feb 04, 2016 · 02:33 UTC#6
I can confirm that this solution does work!  I was going to just pull the fuse, but it is easier to just pull the negative battery cable on my car than to find the right fuse.
I left the battery off for several hours and after reconnecting and testing.... the iphone worked 1.2.3.
Thank you very much for finding this solution for me!
