Here is a link to the 2015 map update for a Avic Z120/X920, maybe someone can hack for you guys.
https://www.dropbox.com/sh/se83vkxrr3zicke/AAAGlyjv9wvlcfEqX-gt2haJa?dl=0
Can I use this on my x920bt? Just upload like normal?
No, it needs to have the password hacked
Oh OK. Hopefully someone can do that.
Thanks for sharing.
They can, it's just a matter of time
I guess the hackers haven't seen this thread.
Someone should pm RonS or pionara, I'm sure they can help
Sorry, that is beyond my skill-set. I never did understand how that hack actually worked internally. I'm a former coder - but on much larger systems. Hell, I almost bricked my HU just playing with this release. Hint - when stuck in update mode - and the HU keeps insisting that you insert the correct SD, you need to get into TestMode and delete \USER\SYSTEM\Download\StartKnd.log.
Remove your TestMode SD (or USB stick), and it should restart into regular mode on next power up.
So were u successful in updating to the newest map?
Yes, for Z110, Z120, and probably X920. See http://avic411.com/index.php?/topic/81643-2015-avic-z120-map-update/
then post #2 for nag screen removal.
Yeah, I was afraid of trying anything. No clue what is going on.
Will wait for supereasy version. Hope he get some free time to work on it.
nvrmind. OP re uploaded the files
Go back to the Z120 thread. Pionara came through and we now have an easier method. super-easy methodYeah, I was afraid of trying anything. No clue what is going on.
Thank you for the files. Updated my x920bt just fine. Work great.
Is the bluetooth firmware for the 2015 map update available? I tried to update the bluetooth firmware that was included with this package but the firmware(3.10) is lower than the one that came with the 2013 map update(3.32). I can't play music through bluetooth using both firmwares With the firmware that came with the 2013 map update, my phone connects and I can make and receive calls but I can't play music through bluetooth audio. With the firmware that came with the 2015 map update, my phone connects but gets disconnected automatically and won't connect until I initiate the connection on my phone.
I'm guessing that I need bluetooth firmware version greater than 3.32? Any help would be much appreciated.
The 2015 upgrade still comes with 3.32.
Would it be possible for someone to upload the 2015 CARDINFO.CIF and VERINFO.DAT files for Z130, Z140, and Z150 users.
Thanks for the reply. I downgraded back to the 2013 map update and everything is working as it should.
I tried to download it for you, but they have that thing locked down and you need permission so it's not easy to get too.
Can someone provide step by step info to update to 2015 map for X930BT? Mine has 2014 map on it. Thanks in advance.
If you choose to actually read the thread you would know that it's not available for that model yet.
Just to spell it out clearly, use this CardInfo.cif file (after unzipping of course) for the above mentioned headunits. Thanks for posting this BlakeStone.
These are the stock files and haven't been password hacked yet correct?
According to the txt file in the zip, VERINFO.DAT has not been hacked. I notice that it is totally different from the one I used from the original 2015 X920bt update (prior to the published VERINFO.DAT hack). The CardInfo.cif file doesn't need any modifications for the newer HUs.
