2015 avic Z120 map update
By kellinaradway · Oct 02, 2015in Hacks/Mods💬 56 posts👁️ 19,892 views
Page 2 of 3
Posted Oct 29, 2015 · 22:51 UTC#26
Hey BlakeStone,
Do you have the actual update map 2015 for the
attachicon.gif2015 Maps CIF DAT.zip
These are for:
AVIC-Z130BT
AVIC-X930BT
AVIC-X9310BT
AVIC-Z140BH
AVIC-X940BT
BlakeStone:  Do you have the actual 2015 map update for the unit posted above?  I tried to put the two files you posted in the zip combine with the 2015 map update files from kellinaradway and it didn't work in the AVIC-Z140BH.
Posted Oct 30, 2015 · 02:48 UTC#27
Sure, but I thought it was just the 2 files that were needed.
Posted Oct 30, 2015 · 06:36 UTC#28
BlakeStone.  Much appreciated.  I tried different cardinfo & verinfo files and none worked on the Z140BH unit so just wanted to try your version.
This version is not the same as the one killiradway posted?
Posted Oct 30, 2015 · 11:34 UTC#29
IT WORKS!!!!!  this version works on Z140BT (mine) and so probably all other newer models.  Basically use everything but replace the verinfo with pionara verinfo file (to bypass the password) and it'll start updating like it should  Many thanks BlakeStone!!!!
I am attaching the Pionara's verinfo file here as well to make it easier for the rest of the guys behind me.
VERINFO.DAT
Posted Oct 30, 2015 · 13:47 UTC#30
random walk, just so i am 100 percent clear, you took the blackstone map update and put the verinfo.dat into it and it worked for 140, does that mean it will work for 130?
Also, any password of passwordpassword or no password at all?
Posted Oct 30, 2015 · 14:43 UTC#31
Just an update. Worked!
Posted Oct 31, 2015 · 00:16 UTC#32
I went ahead and used your file and made a new zip.
Posted Nov 01, 2015 · 23:28 UTC#33
okay, I'm a bit perplexed and will admit that even though I have a good grasp of computers, this thread has thrown me for a loop.  Simply stated, I have an X920BT and above BlakeStone has uploaded a zip file with a CARDINFO.cif that seems to exclude my device.  So what should I go with? The second or so post with the hexedit information, the above link but replace the *.cif file or something altogether different?
Feel free to treat me like the n00b I am. I have the aforesaid device and have not updated past the posted BT update... and that's it.  Thanks in advance.
Posted Nov 02, 2015 · 02:25 UTC#34
Removed - obsolete
Edited Jul 30, 2017 by RonS
Posted Nov 02, 2015 · 12:50 UTC#35
Just an update, the 140 i think may be different than the 130 as far as upgrade. I have a 130 and it has a few issues with apps and bluetooth after 130 update.
Posted Nov 04, 2015 · 17:45 UTC#36
Should 130 users be using the 140 instructions or the 120 ones?  ThePiston, what bluetooth issues?
Posted Nov 05, 2015 · 14:12 UTC#37
My issues are the following,
the app connection settings are bluetooth and wired.
If i choose wired the bluetooth option to stream music doesn't work and the pandora app doesn't work.
Basically music will not play wired or with bluetooth.
If i choose bluetooth for app connection setting the bluetooth connection works however the wired apps don't work and it shows them on the radio as an option (pandora, aha, etc)
It's almost like the 140 update is for 140 oonly and not for 130
maybe someone else can try it and confirm there is an issue.
I would wait till this gets tested more before updating your 130 with 140 update.
Posted Nov 06, 2015 · 14:53 UTC#38
Haven't tried this yet but Just saw this from Ron:
I loaded this on my X930BT earlier today.  Everything seem to update smoothly.  However, my iPod cable no longer work with iPhone 6S.  It can only charge but does not detect a device.  Any recommendation?
Thanks all!
Try this. Seems like a common issue with the Z130/x930. http://avic411.com/i...on/#entry336468
Posted Nov 06, 2015 · 23:25 UTC#39
This also worked for the X920. I thought I was going to be stuck with the 2013 update.
Thank you very much.
Posted Nov 09, 2015 · 20:30 UTC#40
vicdawg, just to confirm you removed power for a few minutes and reconnected, correct?
Posted Nov 09, 2015 · 21:04 UTC#41
Correct.
Posted Nov 10, 2015 · 05:18 UTC#42
I can confirm this worked for my X9310BT, now the unit runs on firmware 6.0!!! I would like to once again thank you all for the contribution having waited 2 years to finally update the unit. A donation will be made!!!
Posted Nov 10, 2015 · 13:23 UTC#43
If you are sure which fuses to pull, that would also work. Remember that there are two power wires (red and yellow) and they are on different fuses (since yellow is always hot and red is switched on with the ignition). I just said to disconnect the battery to be 100% sure.  In my case, I only pulled one fuse the first time and the reset didn't work.
Edited Nov 12, 2015 by RonS
Posted Nov 12, 2015 · 00:03 UTC#44
Is there files for x940bt or x930bt thanks Cd
Posted Nov 12, 2015 · 00:10 UTC#45
I bet if you looked around a little you'd find something like that hint
Posted Dec 12, 2015 · 17:39 UTC#46
Yeah, it's kinda messed-up (but not nearly as bad as the F-series thread  ~600 posts). The original post link is outdated. For X920's and Z110/Z120's use these files. Z120/x920
Get all three, extract them, and put CARDINFO.CIF, FIRMWARE, and UPDATE in the root of a freshly formatted FAT32 SD. Insert into your unit. Once your unit is updated and booted into the new software, go to SETTINGS/Bluetooth Settings and update BT firmware.
Sorry for the delay, but thank you very much for responding. It's appreciated!
Posted Jul 12, 2016 · 19:01 UTC#47
Sirs, I am looking to update the software/firmware/maps/bluetooth on my X920BT.  It appears that the files RonS pointed to for Z120/x920 are no longer at that link.  Can someone point me to the right files?
Posted Jul 12, 2016 · 19:34 UTC#48
Read post #140 here
Posted Jul 13, 2016 · 00:20 UTC#49
RonS,  I hate to bother but am hoping you can help.  I have an X920BT with the following versions:
Version Information X920BT
I'm trying to update to the 2015 version mentioned in this thread.   I have a 64GB microSD card that I have partitioned down to only 16GB (FAT32) on which I have put the 'FIRMWARE', 'UPDATE' and CARDINFO.cif file you listed in post #140.  When I insert the card into the radio, nothing happens.  I've tried removing power to radio to reset but still no joy.  I've tried to read through all the posts that might help but am coming up empty.  Can you help?  Do I need to step up to an earlier version before I go to 2015?  Also, will this update include maps and firmware, including bluetooth?
Posted Jul 13, 2016 · 12:37 UTC#50
Must be your SD. Get a cheap 4 to 8 GB one and don't partition it. Format FAT32 using default cluster size. The boot loader in these units isn't very sophisticated.
Edited Jul 13, 2016 by RonS
Page 2 of 3
