Pioneer 4100Nex Password Screen
By ween101 · Oct 22, 2015in NEX Series💬 22 posts👁️ 39,121 views
Posted Oct 22, 2015 · 15:36 UTC#1
Issue - I have Pioneer 4100Nex  that I had set a password on  my battery died which reset the unit. I am at the password screen know the password but  it seems there was a loss of calibration on the screen and when I tap the bottom row of characters they are not accessible. I called Pioneer and they said pull the unit and send it in and wait 3 weeks and they can clear it out.
Is there any alternative solution for this?
Thanks in advance for any response or assistance
Posted Oct 22, 2015 · 19:25 UTC#2
I had the same problem. I had numbers in my password and couldn't turn the numbers on because it was no on screen. Well Half of the button was sticking up from the bottom of the screen. But no matter what, If I tapped it with a pen end, something very small, it would still hit above it. Pioneer said the same thing. send it in. I was just gonna take back to best buy. but I was messing with it and taking my finger nail and just swirling in around the screen and it finally let me change the keyboard to numbers. but then when i hit enter which is about the delete, it would delete the whole password. then I learned to put the cursor to the left so it couldn't delete anything. So I would just take your finger and twirl it around the screen and don't go straight to the button your trying to hit on the bottom. when going around and when going to to try and hit it, take your finger and start from the opposite side on bottom and drag it on the bottom edge and just stop on the top of the botton your trying to hit. It worked for me. then I just removed the numbers from my password. Never had the problem again. happened in may 5 months ago.. good luck
Posted Oct 22, 2015 · 21:43 UTC#3
Yep that's my problem I have numbers in my password  I used a toothpick to hit the very bottom corner and the above shift/capitalize key is selected
and  same goes for the Go/Enter on the other side
I think what chaps me the most about this is when I called Pioneer and before I half way go out what the issue the gentlemen I was speaking with was already telling what to do made it seem like it was a known issue.
Guess it's easier for them just to have the end user rip out the deck and wait 3 weeks for the reset then to fix the issue all together (sorry for the rant just frustrated )
Posted Oct 23, 2015 · 14:57 UTC#4
incarnato
Much thanks it took a while and it was tedious but it worked
Thanks for taking the time to share the tip :)
Posted Mar 23, 2016 · 17:21 UTC#5
need password recovery for 4100nex
Posted Apr 03, 2016 · 19:58 UTC#6
Yes, if you stole the password-protected device, you can remove the password :)
It is extremely easy and password can be removed just in 1 minute.
This is my first post here.  I didn't steal my 4100NEX, but when I was working on the HU to add some additional cables USB and HDMI to the back it failed to power up right after doing that.  So then I thought the HU was dead.  I then removed the main plug and pulled the 10amp fuse, and plugged it back in, then it finally powered up, and now it's asking for the password I set, but I forgot it.  The password hint shows, but I tried various passwords that I thought I set, but none of them work.  If you could please PM me the procedure I would be greatly appreciative of that.
Posted Apr 03, 2016 · 22:37 UTC#7
Other than any of the tips in this thread I highly doubt anyone is gonna help on your issue, Pioneer service center is gonna  be your best bet.
Posted Apr 03, 2016 · 22:50 UTC#8
Found this but if this is the only option and being a community member of this forum doesn't mean anything, i'll go this route.
Posted Apr 04, 2016 · 02:13 UTC#9
Yup, most of all the posts I've ever seen said they did just that, payed for the fix.
$9 is worth it if it truly works.
Posted May 20, 2016 · 22:55 UTC#10
Did it work. Im in same boat. I bought an open box unit from best buy that had been returned from a previous customer. They didnt check it and when I installed it had a password screen. Now im stuck.  Its a avh-4200.
Posted May 21, 2016 · 13:23 UTC#11
Update. got it booted to testmode.  Where do i find/dump or remove password? i bought this from best buy as a open box unit and they didnt plug it up when returned to see if it needed clearing (the stereo guy got deployed).  They will replace, I just dont want to go to the trouble of ripping the unit out and putting it back in.
Edited May 21, 2016 by sgtstadanko
Posted May 21, 2016 · 15:14 UTC#12
nm. i just hit factory reset. cleared it.
Posted Mar 23, 2017 · 20:03 UTC#13
Hey, I just bought a car yesterday with this deck in it but its password protected. I asked the guy I got it from but he got the deck from a buddie of his and doesn't know the password either. Think you can help me out to remove it?
Posted Mar 25, 2017 · 17:26 UTC#14
(deleted)
Edited Mar 30, 2017 by tedkan
Posted Apr 02, 2017 · 23:33 UTC#15
I have a 4100NEX and i need to find the files to get to TESTMODE so i can recover the password from the unit in my other car
Posted Apr 07, 2017 · 20:09 UTC#16
Posted Apr 07, 2017 · 20:10 UTC#17
What do I need to do to get this info from you
Posted Aug 08, 2017 · 02:47 UTC#18
Here's my working solution for resetting the password on a Pioneer DVD AVH-XXXX head unit:
http://avic411.com/index.php?/topic/83492-password-avh-reset/
Please respond if this helped you out, as I would hate to see people throw their money away by having to pay someone on Ebay for this knowledge.
-Mark
Edited Aug 08, 2017 by cravatts
Posted Jul 05, 2018 · 01:20 UTC#19
any info you can help me with this. Mine is doing the same thing as I just bought it and the owner does not know the password.
Posted Oct 01, 2018 · 00:59 UTC#20
I downloaded the .rar file,  decompressed it and copied the files to a 8 GB USB stick.  I had previously wiped the stick and reformatted it.  I'm using a Mac.  I formatted the USB stick first time as MS-DOS, tried it, nada.  Went back and reformatted the stick as ex-FAT, put the files back on it, checked to make sure they copied over.  Deck still did not recognize the stick.  Now in my case, the deck (NEX 4201) was installed with a USB dongle out to the glove box from port 1.  I have used this connection before to update firmware, and it works fine.  However, in this case, the deck did not see the USB stick, or to be precise, the deck did not go into 'factory service mode.'   I've rooted other Android devices so the process is not completely foreign to me.  Any suggestions?
Posted Mar 28, 2020 · 05:09 UTC#21
Why is no one replying when they say they know how?
Posted Mar 28, 2020 · 05:12 UTC#22
See I had to replace some stuff under the hood ya know, and when I got back in my truck it said password: and had a password hint, I don’t think I ever even put in a password, I bought my pioneer 4100nex brand new too. So I don’t even know what the hint of the hint is lol. Can anyone please tell me in any form what the hell im even doing at all? Because I ain’t even trying to rip it out and send it in and get it back 3 weeks later. PLEASE ANY ADVICE IS GOOD ADVICE AT THE POINT YALL!!! Thanks
me
