- launchMode=TestMode
- testSubMode=Serv Mode.
Password AVH Reset
Bonjour,
Je confirme que la méthode fonctionne avec le modèle AVH-X8800BT
J'ai acheté cette article en occasion suite à un retour de client qui selon le magasin n'a jamais été utilisé.
L'autoradio était bloqué avec un mot de passe.
j'ai économisé du temps et des frais.
Merci beaucoup ![]()
Sorry for translate :
Hello,
I confirm that the method works with the AVH-X8800BT
I bought this item on occasion following a customer return which according to the store has never been used.
The car was blocked with a password.
I saved time and expense.
thank you very much
Fantastic!!! I have been occasionally checking in and patiently waiting to see if someone would eventually find my article and use the information that I spent time writing up. Where are you hailing from? Canada, France, etc.? A response like this give me the encouragement and desire to continue to give back to the community that I learn so much from. Between Youtube and blogs like this, one can learn so much. It wasn't that long ago that the only way I could learn how to do something was to go to a library and hope that they had a book, magazine, etc. that had the information that I was trying to find.
-Mark
This totally worked for me....thanks! Used the rar version ![]()
Worked for me too. Thanks!!!!!
It didn't work at first and took some troubleshooting. I was using a 16GB USB drive with no luck. Researching I found info saying to use a 1GB - 4GB USB ONLY. So I found a small USB (1GB) drive and it worked perfect.
thanks.
workED like charm....
I could not remember my password and was dreading sending it out to Pioneer. Luckily I came across this thread and it worked for the avh4200nex. Literally just used it. Downloaded the .rar file and extracted the files prior to copying to the thumbdrive.
Thanks very much for this! Greatly appreciated!
THANK YOU SO VERY MUCH!!! This method works for the AVIC-5000NEX AS WELL. My unit has been locked up because the screen calibration went off after the last firmware update and I replaced my battery... Much respect and appreciation. BLESS
Hello I got the text mode menu I see number 6 initialize to factor default is that it because I did that and it still show the password screen
I am not tech savvy at all, but this worked!!! I thought I was either going to have to buy a new radio or pay someone to erase the password. Thank you for the help:)
I tried this method, didn't work for me. But the smallest flash drive I found was 16gb. So I'm gonna try to find a 4gb or smaller and try that
OMG!!! It fcuking works!!! Thanks a lot! LOVE YOU!!!
Screw greedy PIONEER!!
worked great. 4100NEX. Thanks, man. I was ready to put the damn thing back in the box and return it until I found your thread.
Could my buttons be messed up? I get into the boot menu but when I try to select "initialize to factory default" I can't scroll down that far. It only lets me see the version information or goes all the way down to "clear sensor data" and shows "ERROR" on the screen
I have the 4100NEX. Cant get it to go into test mode. Ive extracted, from the dropbox .rar, the individual files on my flash drive and waited about 15 min. I can see the access light blink on my flash drive but its not booting up. Ive tried a 16GB, 4GB and 1GB drive. All formated to FAT32. Does anyone else got any advise to send my way. Thanks.
Thank You. works on a avh-4100nex!
On 4/17/2018 at 11:25 PM, avicpyro said:Thank You. works on a avh-4100nex!
Hi. What did you do to get it to work? I plug the flash drive in and it just sits there at the password screen. How long did wait? Did you have to hit a button for it to switch to test mode?
it took less than 30 secs and it restarted by itself into the service mode.
i used the contents of rar provided in the OP. formatted the stick to fat32 (not quick format) and it just worked.
make sure to use USB 1. or the first USB. not the 2nd.
What firmware are you on? I upgraded to firm 1.10 before this happened. I've been driving around with the files on a 2 GB flash drive for the past few days. Not a single thing has happened.
hi
the img files are winzip,is necessary to unzip?
thanks
Tried this for about a week now on my AVH-4000NEX. I can easily navigate to the Initialize Factory Reset, it gives the OK on all section except GPS, Turns Blue and says to turn off power to test Bluetooth. After I remove the USB and restart, same old password screen.
On 4/25/2018 at 8:06 PM, HouZanShi87 said:What firmware are you on? I upgraded to firm 1.10 before this happened. I've been driving around with the files on a 2 GB flash drive for the past few days. Not a single thing has happened.
i'm on firmware 1.03 i think. definitely not the latest...
On 5/4/2018 at 6:37 AM, paulo andre said:hi
thanks
files used rar so i used winrar to extract as OP mentioned.
i also made sure the flash drive was clean of anything else. i used a 1GB flash drive i had lying around....
On 5/7/2018 at 5:40 PM, 88MikeCoop said:Tried this for about a week now on my AVH-4000NEX. I can easily navigate to the Initialize Factory Reset, it gives the OK on all section except GPS, Turns Blue and says to turn off power to test Bluetooth. After I remove the USB and restart, same old password screen.
Apologies but im not familiar with that part of these, total noob aside from what i've read and the little success i've had here. but if the issue is related to GPS. is there anything physically that may be missing with that part?
I thought my unit was toast. Touch Calibration was off, could not enter password. Copied the files on 16 gb thumb drive and inserted in #1 USB. Booted up to Password Screen and in a couple of seconds, the option screen came up and scrolled to factory reset. After reset, cycled power off then on. Asked if I wanted to set password and I declines. After this, I reformatted thumb drive and unzipped latest firmware onto it. Updated the firmware and everything is operating correctly. A Big Thank You to You. Saved me some money.
Has anyone got this to work on the latest firmware? I've read on another post about a "golden egg" file but the link to it was dead. Does anyone know what that file is? I've tried a few different size USB sticks all formatted to fat32 with the files extracted to the root dir of the flash drive. I've at least lucked out that since I use Android Auto I can still play music and use audio nav. But I can't take calls anymore since that does it via Bluetooth and the radio blocks that audio channel.
