AVIC-F310BT bricked? Urgent help please!
By odinas112 · Dec 28, 2015in Hacks/Mods💬 11 posts👁️ 3,375 views
Posted Dec 28, 2015 · 16:40 UTC#1
Hello. I've tried upgrading my AVIC-F310BT maps to 2015 version, everything was fine untill it reached 99%, it said "error occured" or something like that, and there was only one option to select - "retry". I've tried turning it off, taking the SD card out, then it asks for one. Nothing helps. Any ideas?
EDIT: sorry, I've just noticed that this is in the wrong section. Any moderators could move it to troubleshooting section?
Edited Dec 28, 2015 by odinas112
Posted Dec 28, 2015 · 17:36 UTC#2
I've managed to get out of the "update cycle". Music is working, but navigation is just black screen. Any ideas what should I do?
Posted Dec 28, 2015 · 21:15 UTC#3
Hi odinas decompress this link and put inside a sd card with testmode next
the link of map poi inside take only map you are sure to use (terminaison .fbl only)
https://drive.google.com/file/d/0B4MAukIOceEXc2dLb0psakdPR28/view?usp=sharing
testmode link
https://drive.google.com/file/d/0B4MAukIOceEXS0l5MC1IQ28tLVE/view?usp=sharing
and ezrider link  put him next the other folder and when copy him inside igo directly
https://drive.google.com/file/d/0B4MAukIOceEXTnlMb3ZpOWwwRVU/view?usp=sharing
to use map put this folder after decompress in igo directly it's license
https://drive.google.com/file/d/0B4MAukIOceEXN1hSTENLUlRfSkE/view?usp=sharing
Edited Dec 28, 2015 by guizmo
Posted Dec 28, 2015 · 23:38 UTC#5
Hello Guizmo, I really appreciate your help. I'm downloading the files as we speak, but there are few things I don't understand. Do you think you could try to explain me a little bit more?
What should I do wiht the downloaded files? I've used testmode to get out of the "update cycle". You are saying that I need to use it again, what for? Is there any way you could try to explain everything again to me? :( I'm really depressed as I cannot work it out..
I don't think that I've used iGo before...
Posted Dec 29, 2015 · 10:18 UTC#6
Hi do this first  the program of F310BT is the same
and after take your copy of your flash disk in safe place
after make a copy of your flash disk in windows pc only open your flash disk and copy inside all files i give you  in the right place
dem,poi,map,license,building,ezrider to replace your files after this take your changed copy put in the sd card with testmode folder near your flash disk folder
in your avic and turn on your avic copy your flash disk in the storage card to your flash disk inside your avic  like this (only difference is for you to copy dem,license)
Posted Dec 29, 2015 · 11:41 UTC#7
Hello. I've started TestMode, and this is my flash disk folder.
I don't think iGo is installed.  Also, I did backup of these files. What next?
Posted Dec 29, 2015 · 12:02 UTC#8
Hi can you open setup and tell me what is inside and prg0 and prg1and system to see  inside
Posted Dec 29, 2015 · 12:13 UTC#10
I've seen this thread, but pionara crack link is not working anymore...
Here are the folders you asked
Prg0
12465377_1094504270581345_838379324_o.jp
Prg1
12443837_1094504367248002_1466559401_o.j
Setup
12436581_1094504497247989_154444132_o.jp
Posted Dec 31, 2015 · 17:00 UTC#11
The AVIC F310 is not the same as the AVIC F710.
The avicF310 has flashdisk 1 and  flashdisk 2
Which card is the Avic F310 get updated ??
Can you put a copy on the forum here from the mapudate.
Regards
