2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
By pug · Sep 18, 2013in Hacks/Mods💬 445 posts👁️ 226,654 views
Page 1 of 18
Posted Sep 18, 2013 · 20:42 UTC#1
2013 European Map Update for AVIC-F30BT, AVIC-F930BT, AVIC-F9310BT, AVIC-F40BT, AVIC-F940BT, AVIC-F840BT, AVIC-F8430BT and some older models.
I have uploaded the files here:
http://www.4shared.com/rar/mwirjwPQ/pioneer_2013_updatepart1.html
The password for the archives is:
openmeup2013
Special thanks to Pionara for the crack which can be found here:
http://avic411.com/index.php?app=core&module=attach&section=attach&attach_id=15552
Couldn't have done it without his skill.
For those who are wanting to run this on other earlier headunits then try this cardinfo file that Travolta supplied:
http://avic411.com/index.php?app=core&module=attach&section=attach&attach_id=15554
So far it's confirmed on a F20 headunit so may work on others.
Any of the above try at your own risk, I am in no way responsible if you brick your headunits.
INSTRUCTIONS (supplied by Travolta)
To do the update on an F930BT you just have to:
01) Download the files from the links above.
02) Extract them to a safe place.
03) Open the extracted folders and go into the Update folder
04) Replace the VERINFO.DAT with the above one.
05) Copy everything you extracted onto a clean 4GB+ SD Card which has been FAT32 Complete Formated
(make sure that the files and folders on the root of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif
06) Put it in your Car (with the engine running or on a charger etc)
07) The Pioneer will ask you if you want to run the update choose ((yes)) the device will reboot and start the update.
08) Wait untill the update is completed
09) Once completed, it may ask you to update again, if so, select ((No)).
10) If you want to update your Bluetooth firmware then, enter Bluetooth settings and update the bluetooth firmware.
Please be sure that you did everything as mentioned above. It's better to make a backup of your system before updating.
For those with Avic F10BT,  F20BT or F920Bt
Download the CARDINFO.CIF from above.
OR
Open the original CARDINFO.CIF in text editor, search and replace this:
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR
If you did everything correctly, you will have your AVIC updated to version 5.0 with the newest Europe Maps
TIPS
You have to apply the update before you can do any modding to remove nag screens etc. All system files have to be original.
Backup your TTS language files if you use anything other than English files before flashing as you may lose them and they revert to English.
If you didn't backup your TTS files some of you may be lucky. Frisk has created a thread listing a few of the TTS files.
Can be found here: http://avic411.com/index.php?/topic/37449-get-your-tts-files-backup-for-avic-f930btf940bt-here/
Edited Oct 08, 2013 by pug
Posted Sep 18, 2013 · 20:59 UTC#2
Well done Pug and Pionara!
Posted Sep 18, 2013 · 21:24 UTC#3
openmeup2013
I purchased the original update files and am happy to share. However if you wish to donate a SMALL contribution to help towards the updates it would be gratefully received.
hello, I've tried installing it on my F10BT and I think I have to change some ahcer any file. Could you tell me how could I do?
Posted Sep 19, 2013 · 05:26 UTC#4
Hi, take attached CARDINFO.Cif
Or
Open the original in text editor, search and replace this:
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR
It will work, flashed my F20 this morning on my way to work and it worked like a charm.
CARDINFO.zip
Edited Sep 19, 2013 by Travolta
Posted Sep 19, 2013 · 11:49 UTC#5
Or
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR
Added to first post. Thank you.
Posted Sep 19, 2013 · 12:04 UTC#6
For those who have donated up to now, thank you so much, it is really appreciated.
Will be getting further updates as and when they become available and will definitely share them with you all.
Posted Sep 19, 2013 · 18:38 UTC#7
Hi Guys,
Thank you very much for the files.
If i unpack the 5 files i get one update 3,37 gb, right?
in that update is a verinfo.dat.
Do i need to replace the verinfo.dat with the one from pionara?
than i put all the files on a 4 gb sd card and put it in the unit and the install starts automatically?
Maybe its a good idea, to make a guide for dummies? just like last year?
Again, thank you very much.
Edited Sep 19, 2013 by driverke
Posted Sep 19, 2013 · 18:52 UTC#8
You got it. Will add to the first post later.
Posted Sep 19, 2013 · 19:05 UTC#9
woohoo, great!
thanx!
Posted Sep 19, 2013 · 19:48 UTC#10
@PUG
here are the instructions, you can put them in the first post.
INSTRUCTIONS
04) Replace the  VERINFO.DAT with this one.
(make sure that the files and folders on the route of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif
Download this  CARDINFO.CIF
Open the original CARDINF.CIF in text editor, search and replace this:
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR
If you did everything correctly, you will have your AVIC updated to version 5.0 with the newest Europe Maps.
Regards
Posted Sep 19, 2013 · 20:26 UTC#11
Thank you,
Very good instructions
Posted Sep 19, 2013 · 23:12 UTC#12
Hi guys,
I'm getting a few wrong password errors when unpacking these. Has anyone else had issues?
Cheers,
Paul
Posted Sep 20, 2013 · 03:26 UTC#13
Hi guys,
Cheers,
Paul
openmeup2013
Posted Sep 20, 2013 · 08:16 UTC#14
If you continue having issues maybe try downloading again in case the files corrupted during download.
Posted Sep 20, 2013 · 11:08 UTC#15
I do not do well the steps to download. File pulsel primerocuando 4shared dredirecciona you to a page where you must register, after registration, you have to press the button download, redirect you again, and then where it says free download 20 seconds. wait and you will leave the window to save. a greeting
Posted Sep 20, 2013 · 11:11 UTC#16
People who want fixed cameras, to send me a private message and I send you.
Posted Sep 20, 2013 · 12:19 UTC#17
Hi all,
Update works like a charm on a f930bt.
Follow the steps in the post of Travolta and  u will have the 2013 maps.
Thanks for all the good work!!!
Posted Sep 20, 2013 · 15:14 UTC#18
Hello.
Last year i have update my F-9220BT successfully via this fórum.
I presume i can use this work to update my unit.
Posted Sep 20, 2013 · 15:15 UTC#19
A very big thanks to PUG and PIONARA
Posted Sep 20, 2013 · 18:18 UTC#20
Discuss what changes have you noticed in the update.
Posted Sep 20, 2013 · 20:01 UTC#21
openmeup2013
Yep, it was corrupt downloads. Downloaded it again, for the 3rd time and it unpacked just fine.
I'll get it installed and drop a little donation pug's way.
Paul
Posted Sep 20, 2013 · 23:20 UTC#22
Can the file from Pionara also be used for an F940BT?
Posted Sep 21, 2013 · 00:25 UTC#23
Everything fines in my F9220BT unit.
5.0 version maps and 3.32 firmware Bluetooth
Thanks one more time to Pug and Pionara
Posted Sep 21, 2013 · 06:43 UTC#24
thx so much!
I will test it today!
Posted Sep 21, 2013 · 07:56 UTC#25
Yes it can, Pionaras file is used with all updates 30 and 40 series models.
Ignore the cardinfo file, not for you.
Page 1 of 18
