2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
By pug · Sep 18, 2013in Hacks/Mods💬 445 posts👁️ 226,654 views
Page 3 of 18
Posted Sep 27, 2013 · 12:24 UTC#51
you've said, as you say it is.
what u mean ?
Posted Sep 27, 2013 · 13:09 UTC#52
TTS Files are the same since 2009 so you can keep using them with the 2013 update...
If you speak italian, it would be great to share ITI TTS files!
Posted Sep 27, 2013 · 13:42 UTC#55
yes without any problem , give me the time to make a rar and upload it aand then write you here the link .. 8) ,
can u help me whit my question ?
AVIC-F10BT - AVIC-F20BT - AVIC-F30BT, AVIC-F930BT, AVIC-F9310BT, AVIC-F40BT, AVIC-F940BT, AVIC-F840BT, AVIC-F8430BT
KJJARRH8R51UX72EUR what units upgrade ?
X07EURX27EURX30EUR what unit upgarde ?
Edited Sep 27, 2013 by Marcello
Posted Sep 27, 2013 · 13:54 UTC#57
in the first post, pug said :
"For those with Avic F10BT,  F20BT or F920Bt
Download the CARDINFO.CIF from above.
OR
Open the original CARDINFO.CIF in text editor, search and replace this:
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR"
so I guess that X07EURX27EURX30EUR is for F10BT, F20BT and F920BT
and KJJARRH8R51UX72EUR is for other models... (it worked with my 930bt)
thanks in advance for ITI TTS!
Edited Sep 27, 2013 by frisk
Posted Sep 27, 2013 · 21:27 UTC#58
can anyone confirm that this works on the f900bt
Posted Sep 28, 2013 · 10:30 UTC#59
OR
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR"
mmM..
F10BT = X07EUR
F20BT = X27EUR
F920BT = X30EUR     ()i think is correct
KJJARRH8R51UX72EUR is for ? AVIC-F30BT, AVIC-F930BT (sure), AVIC-F9310BT, AVIC-F40BT, AVIC-F940BT, AVIC-F840BT, AVIC-F8430BT :huh:
Edited Sep 28, 2013 by Marcello
Posted Sep 28, 2013 · 10:37 UTC#60
UPLOAD IN PROGRESS  8)  8)  8)  8)
Is all list and not only ITI ,
ps. ADMIN : can i share it here ??
Posted Sep 28, 2013 · 12:01 UTC#61
thanks for the effort... don't worry for the link to the TTS files as in the first post there are links to download the whole 2013 update! :mrgreen:
there is a long time I want to create a thread with individual link for each TTS files to help members without there TTS files (and without asking money for this...) but GED, ITI and ROR are still missing.
I can't see on the thumbnail if these 3 are here or not (it's really too small!)
Edited Sep 28, 2013 by frisk
Posted Sep 28, 2013 · 19:45 UTC#63
perfetto! 8)
EDIT : Now that I have all 18 languages, they are individually available here, ready to be restored!
Posted Sep 28, 2013 · 22:46 UTC#64
Hi,
Thanks for all the info first of all! I tried to do the update, but it failed. Got a 1 khz tone instead when I used the SD cart with all the data provided here.
Maybe I missed a step in between? Currently my Pioneer AVIC-F910BT has maps of 2008 (!).
This is my version, do I need to update the firmware first?
Edited Sep 28, 2013 by xer03
Posted Sep 29, 2013 · 07:50 UTC#65
Sorry, but too many topics..i didn't understand...
for F940BT the procedure is the same of the 1st topic????
thanks at all...
regards
Posted Sep 29, 2013 · 07:56 UTC#66
940bt is a 930bt with 2012 software and map so... yes, you can follow the first post to update your 940bt.
Posted Sep 29, 2013 · 08:16 UTC#67
Hi,
Sure you need to update the firmware. Just download the files in the first post, download and replace the VERINFO.DAT and CARDINFO.cif put all on your FAT32 formatted SD-CARD and start the update on your device.
Edited Sep 29, 2013 by Travolta
Posted Sep 29, 2013 · 08:18 UTC#68
thanks at all...
regards
But you don't need to change the Cardinfo.cif  just use the original one.
Posted Sep 29, 2013 · 16:12 UTC#69
I downloaded the package, replaced the VERINFO.DAT and CARDINFO.cif and placed it on a complete formatted sd-cart. Still no succes unfortunately...
When I put the sd-card in the navigationsystem and start the car, eventually it comes up with only audio, it bypasses the installdata.... Seems the system only recognises the example .wav files, that are located somewhere in the download package.
Is it not working because I have a very old version allready installed and need to upgrade first, before I can upgrade with this package or something else? Thanks again. My Pioneer is a F910BT
Edited Sep 29, 2013 by xer03
Posted Sep 29, 2013 · 17:43 UTC#70
Sorry was my mistake, this update will not run on your device F910BT, you can use AvicNet 2.1 form this thread for your device.
Posted Sep 29, 2013 · 18:11 UTC#71
Thanks Travolta. Keep up the good work !
Posted Sep 30, 2013 · 08:58 UTC#72
:mrgreen: works on F940 - at first there was a "wrong SD card" problem, caused by a noname SD card - solved by using a higher quality 16GB micro sdhc.
Many thanks to all of you, great job!
Posted Sep 30, 2013 · 09:18 UTC#73
Thanks to Travotla and frisk...last question...
i have Pioneerus installed....
better to remove first...and then upgrade maps??
i think yes....
Posted Sep 30, 2013 · 10:47 UTC#74
You mean you have a US-Version installed?
If yes, depending on the Version of your device, change the CARDINFO.CIF to that version and try to update without dowing anything else. If not then you have to remove it.
Normaly, the update compares the version No. and the device version.
Regards
Edited Sep 30, 2013 by Travolta
Posted Sep 30, 2013 · 14:01 UTC#75
i think yes....
if you read the last post in the pioneerus thread, there may be an issue to run pioneerus and the 2013 update together... or not, as the member who complain (oscarboiro) don't say if he managed to run pioneerus with the 2012 update before updating to 2013. :mrgreen:
maybe you should ask there... or wait until someone here confirme that he's using pioneerus with 2013 update. (or try yourself and tell us :-P )
Edited Sep 30, 2013 by frisk
Page 3 of 18
