2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
By pug · Sep 18, 2013in Hacks/Mods💬 445 posts👁️ 226,654 views
Page 5 of 18
Posted Oct 06, 2013 · 19:20 UTC#101
hi, guys. can anyone tell will this all work on f3210bt (or 320bt)?
Downloaded, copied over and tried with both .cif file versions. Nothing happens though upon inserting/restarting the device. Doesnt fit f3210bt or other issue?
Anyways, if this cannot be installed can some share a thread for newest update available for this unit (f320bt or f3210bt) please?
Posted Oct 07, 2013 · 04:42 UTC#102
I think you can install IGO, Navitel, Navigon and a lot of other software with the newest maps on your F320BT. Just search for igo and F320bt.
Regards
Posted Oct 07, 2013 · 10:09 UTC#103
Thanks for your help
Posted Oct 07, 2013 · 10:45 UTC#104
Regards
Thanks Travolta. Will try, if wont find a way to update navgate as Id rather have this one updated, instead of having to fire up a seperate navi app..
Posted Oct 07, 2013 · 10:51 UTC#105
is it possbile to update my F930bt to the latest igo maps? ive upated to the maps on this thread, but want to update the latest igo maps? can this be done?
Posted Oct 07, 2013 · 13:21 UTC#106
in order to use tomtom, igo and other navigation softwares and maps on a f930bt, for the moment the only option is pioneerus.
the dedicated topic is here...
Posted Oct 07, 2013 · 18:42 UTC#107
Hi!
Is it possible to update my F900bt with this?
Posted Oct 09, 2013 · 04:47 UTC#108
Hi!
No, you can use this one AVICNET 2.1 or this one
Regards
Edited Oct 09, 2013 by Travolta
Posted Oct 09, 2013 · 14:41 UTC#109
Hi all, thanks for your effort, i tried 3 microsd with no luck... i don't know if these doesn't fit or are my files, so, can someone tell me files, folders and dimension of the update??
FIRMWARE
Update
CARDINFO.CIF
When i select properties for this items i have 220 files, 21 folders and 3,37 GB (3.623.875.032 byte). Is that correct?
last thing, i have to make a label for the volume of microsd or can i leave blank?
Thanks in advance for reply
Marco
Posted Oct 09, 2013 · 15:48 UTC#110
The files are correct 220 Files and 21 folders 3,37 GB (3.624.120.320 Bytes)
Please make a full format on the SD, it takes longer but to be on the safe side. Copy the whole folders and files to the root of the SD. You may need to create the OPENING.FLG with 0KB, put it in this folder Update\USER\SYSTEM\BG
I remember the update won't start on my AVIC F20BT until I've created this file.
Regards
Posted Oct 10, 2013 · 17:50 UTC#111
super !!!!   AVIC-F9310BT  ok !! (version PL)  :-P
Posted Oct 10, 2013 · 18:32 UTC#112
I'm really pleased 8)
Posted Oct 10, 2013 · 20:22 UTC#113
Hi everyone
F9310BT updated successfully :-P Two in a row !!
Thanx to Pug & Pionara
Posted Oct 12, 2013 · 13:28 UTC#114
Hi
when i put into the sd card on my F10, he told me to write the code for pioneer. Who s this code?
Please help!!
Posted Oct 12, 2013 · 18:25 UTC#115
Hi
Please help!!
You have to make some changes to the F10. read carefully
INSTRUCTIONS
To do the update on an F930BT you just have to:
01) Download the files from the links above.
02) Extract them to a safe place.
03) Open the extracted folders and go into the Update folder
04) Replace the VERINFO.DAT with the above one.
05) Copy everything you extracted onto a clean 4GB+ SD Card which has been FAT32 Complete Formated
(make sure that the files and folders on the root of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif
06) Put it in your Car (with the engine running or on a charger etc)
07) The Pioneer will ask you if you want to run the update choose ((yes)) the device will reboot and start the update.
08) Wait untill the update is completed
09) Once completed, it may ask you to update again, if so, select ((No)).
10) If you want to update your Bluetooth firmware then, enter Bluetooth settings and update the bluetooth firmware.
Please be sure that you did everything as mentioned above. It's better to make a backup of your system before updating.
For those with Avic F10BT,  F20BT or F920Bt
Download the CARDINFO.CIF from above.
OR
Open the original CARDINFO.CIF in text editor, search and replace this:
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR
If you did everything correctly, you will have your AVIC updated to version 5.0 with the newest Europe Maps
Posted Oct 12, 2013 · 18:27 UTC#116
Hello together,
the update was succesfully. Thanks a lot. Unfortunately the remote control on my steering wheel doesnt work anymore :(
can anyone help me ?
its an Audi A4 from 2006
cheers
Posted Oct 12, 2013 · 22:22 UTC#117
FULL SUCCESS ON AVIC-F9220BT on my Italian Ford Mondeo!
Firmware (22 minuti)
Bluetooth (4 minuti)
Il Cardinfo.CIF va modificato a mano come da istruzioni.
Thanks to Pug, Pionara and Travolta
Edited Oct 12, 2013 by bompa
Posted Oct 13, 2013 · 06:34 UTC#118
Hi
Do you have a security code (PIN) for your Device?
Posted Oct 13, 2013 · 15:42 UTC#119
Dutch update f9310bt works great
Posted Oct 13, 2013 · 19:47 UTC#120
Hello together,
Strange, you've updated your device and not the steering wheel remote control! Is this a manufacturer remote or after market one? Can you tell me the brand and the manufacturer of this device, maybe some one have this remote and can help you. I'll also take a look for you.
Regards
Posted Oct 14, 2013 · 04:39 UTC#121
Hi Travolta,
thanks for your answer. The radio just needed another reboot. After the update it doesnt work. next day after switching off the motor it works again.
so everthing works perfect. Thanks again. was looking long time for an update.
cheers und viele Grüße :)
Posted Oct 14, 2013 · 05:20 UTC#122
Gern geschehen. 8)
Edited Oct 14, 2013 by Travolta
Posted Oct 14, 2013 · 19:30 UTC#123
Hi Travolta,
My parents in law have a f710bt and im searching for the 2013 eu update + maps will this work also?
Or can you help me further?
regards
Posted Oct 15, 2013 · 04:41 UTC#124
Hi Travolta,
Sorry but this one is not suitable for your device. you can use this one AVICNET 2.1 or this one
Edited Oct 15, 2013 by Travolta
Posted Oct 16, 2013 · 15:06 UTC#125
Thanks for this post!
I have browsed thru the whole post but didn`t find any answer.
I have a unit with a map from USA, and i drive in Norway/europe. The 2012 update (wich i didn`t get to work) i saw someone who used a VARINFO from a US update, do anyone here have that?
I actually can update my bluetooth, but the setup isn`t starting when i put in the SD card.
I run a x940bt
-Thanks
Page 5 of 18
