The files are correct 220 Files and 21 folders 3,37 GB (3.624.120.320 Bytes)
Please make a full format on the SD, it takes longer but to be on the safe side. Copy the whole folders and files to the root of the SD. You may need to create the OPENING.FLG with 0KB, put it in this folder Update\USER\SYSTEM\BG
I remember the update won't start on my AVIC F20BT until I've created this file.
Regards
Hi all, thanks for your effort, i tried 3 microsd with no luck... i don't know if these doesn't fit or are my files, so, can someone tell me files, folders and dimension of the update??
FIRMWARE
Update
CARDINFO.CIF
When i select properties for this items i have 220 files, 21 folders and 3,37 GB (3.623.875.032 byte). Is that correct?
last thing, i have to make a label for the volume of microsd or can i leave blank?
Thanks in advance for reply
Marco
Thanks for reply Travolta, now i have your exact dimensions and i tried with and without OPENING.FLG, my f930bt won't start update, made last year without problems with 2012 update in this forum. May be was this that prevents me to make the update now??
I don't know what else i can do... i tried several microsd without results, may be you have some suggestions, hope so!!
Marco
