anyone can make a photo to the power cord to see where is the violet/white cable?
thanks
thanks
Thank you for this. Worked a charm on my F840.
does this also works on a F500BT?
Hi,
I have an AVIC-F9210BT. I cant get the testmode working. I have download it and put the files on the root on the SD card. But my radio just start up normaly.
What i'm I doing wrong?
/Claus
Thanks Travolta. I will try that. But I actually just took a change and upgrade without backing my unit up first. And I was upgrade with success, thanks to the guide in here.
But I could back it up now. Would that not give me a backup in case a upgrade goes wrong in the future or should I have done it before I upgrade with the software in here?
I try Condi's HACKMODE v2.21 - AUTOINSTALL, because I thougth was I could get into testmode with that tool, but I could not. Do you know if all the files from "Condi's HACKMODE v2.21 - AUTOINSTALL" are remove after I have upgrade to 2013 maps and version 5 of the software on my AVIC-F9210?
/Claus
Normaly yes, if you run the update, it will overwrite all the stuff. For future updates we will be available to help people to get the stuff working. But you can keep this update on a USB-Flash-Drive to use it if the future updates failed.
Regards
Regards
Cool. Thanks
Hi,
i have a 910BT,can i transfer only the your new maps with testmode
License or other elser are to change too?
Philippe
No, I don't think that, you don't know which files will be transfered and updated when you run the update. On the other way, it will take hours to copy the NDATA Folder, the update takes only 20 Minutes and if you run it as in our description, nothing can happen.
Regards
Hi,
Ok i have understoud!
I have other questions
does this release fit for a F910BT?
If yes,could it read FTR files for trucks after update?(with special maps) because it would be very helpfull to drive my camping car!
Thank you for your help!
Regards
Hi,
I have an F20BT.
I downloaded the files, replaced the Verinfo.dat and the cardinfo.cif, put all on an SD card. The SD card was slowly formatted first.The file 'opening.flg' is already in the directory Update\User\System\BG
I'm getting the message (translated from Dutch)'wrong SD card, put in right card'.
I've redone the whole exercise but still I get the same message.
I saw that others were facing the same problem but appearently they could fix it but formatting the SD card and placing the
I'm really looking for some good advice as I can't get my system running anymore.
Please help!
Kind regards, Jan
I downloaded the files again and it seems that winrar did some more extensive unpacking now.
In the directory UPDATE\NDATA\ it now unpacked 106 files while with my previous attempt it unpacked into only 1 file of >3GB over there.
I'm slowly formatting a 8gb SD card now at this moment and then will try again.
I'll let you know if I succeeded.
Regards, Jan
@Jan
When you extract the files you must have, 220 files, 21 folders and 3,37 GB (3.623.875.032 byte). Is that correct, do you have these files? If not, try to download with IDM (Internet Download Manager) it resumes the download and in that way you will avoid any corrupted files. You can also try a new SD-Card.
Regards
Hi Travolta,
It worked with the 106 files in the directory UPDATE\NDATA like I mentioned in my previous message.
I did not count if in total there were 220 files, but appearantly my problem was that there was 1 big file in the UPDATE\NDATA directory while there need to be 106.
Futhermore I did use another SD card of 8GB in stead of the 16GB one I used yesterday (mid)night (...).
I did a slow format with the default clustersize selected.
Thanks anyway for responding!
Kind regards, Jan
thanks for everything
my pioneer 9220 full working ![]()
F30BT Working.. Thank U very much. System is faster too. ![]()
After update my f9220bt everything was perfect. Couples days after i experienced some malfunctions:
1 very long boot time (sometimes)
2 need to unplug and to plug usb memory after switching engine.
Any idea?
Infected usb/sd memory usage?
Hi "eastdick"...I too have a F30BT, would you tell me exactly how I should do?
Thanks a lot in advance!
Ciao
EDIT:
A questions:
where to insert the voice directory with that name, once prepared the sim card?
Hello Travolta, maybe you can help me. I have upgraded my F930BT couple months before with 2012 map (if I'm correct this one was from pionara). Now I has download all parts and I thought everything will be ok, but when I insert SD card he don't ask me to update it. I'm going to bluetooth settings for firmware update and there is written :
Current: ver. 3.24
New: ver 3.32
So I understood that with SD card is everything ok and it should ask me to update. What can be wrong? Or I should download all parts and try again?
Best regards
