Hi to all... i update my f40Bt correct with the first page instructions, 20 min instalation and no errors get, but i think something is wrong, because my TTS SPS (Spain) where on the correct place and dont lost TTS languaje, something is wrong? how can i check Map and firmware version?
2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
Hi
I have updated successfully (f930bt) however i cannot get video in app radio with iPhone 4s - can anyone give me input on troubleshooting?
Hi
I have the same problem with f920bt and iphone 4s. I see black screen and no apps.
I have CAN-BUS adapter with Pioneer AVIC-F9310BT and Seat Leon 2011. When i wont change the chanel of radio, not get for 1 station, but only for 0,05MHz.
How can fix this ?
Go to information under settings and there you'll see the version
How can fix this ?
Have you ran a scan for the channels? Normaly if you ran the scan the channels will be saved automatically. Is your Antenna connected probably to your device? Please check and confirm.
yes, i see this, 5.0, but not show me any info about map version... it is right? because i have one road that do not show this update and i am confused
I update and dont loose my TTS languaje
No i save channels manual, is this a problem ? What muss to do, select search BSM ?
Thnx
Hi guys, first of all thanks to all of you for your work...
I'm ready to update my Avic F940BT that It's on my Alfa Romeo (thanks even for TTS italian zip then...
Is it possibile to make a backup of everything before starting the update? (to use to revive my device if something goes wrong with it)
Will the system language (device menu) be in Italian or only in English (and other languages provided with the update)? Is it possible to change it?
Sorry for my English... I hope somebody can help me... Thanks again...
Succes on F10BT without any problems !!! JUST PERFECT !!! many thx
Hello,
yes my device is connectet to antenna. I have problem with changing station with steering wheell button. Not changing for the 1 station but only for 0,05MHz.
What can i do ?
CAN-BUS adapter is original Pioneer, my avto Seat LEon 2011
Thnx
Anyway to remove the anoying nav ok screen with the new software on the F940bt?
Hello,
Links are not working for the download at first page
I have updated my 9310bt last year by using this website and it was perfect and looking forward to update this year as well , I have seat Leon 2011.
May need help for the donation issue ( how to do etc)
Thanks a lot for your support
kind regards
Hi Guys!
It's my first post here.
I have the F30BT and I was trying to update both firmware and the EU maps.
Unfortunately the download links on the first post are not working anymore.
Is there any chance that you could upload them again? Via torrent or so...
Thanks in advance!
Best Regards
I do the update, and now all works perfect.
Any question:
I have an android phone and now I see that there is a new program named "aha".
I open the app in my android phone, I switch on the blueetooth on it and then I click on the aha program on my avic f20bt...
and nothing more happen..
I read the FAQ of aha, and I see that if I have an android phone the phone should connect to the pioneer avic f20bt without cable..
+1
pes la verda va todo bn pero el gps se pierde mazo y no tiene casi nada de señal una putada yo tenia el original del 2011 y iva de lujo pero claro estaba viejo pero se redirigia rapido iva bn no se perdia nunca ( tengo un avic f930bt). voy a intentar aser la atualizacion de nuevo aver si mejora o ise algo mal pero lo hice bn cambie el carinfo por el 5 todo , encima no ise copia de segurida , tampoco me preocupa mucho siempre saldra algo mas pero decidme please si alguien ha notado esto
Links are fine, instalation was easy, everything works. Thanks man!
f9220bt
Anyone tested/tried to do the update on a F840BT? (from my understanding it is the same as the F940BT?
Also Anyone able to point me to where to find the testmode.key file for my device? (i got the link on how to back up from eariler in the thread)
Any ideas if this can be done from usb or only Sdcard?
And from my understanding i only need to do:
To do the update on an F930BT you just have to:
01) Download the files from the links above.
02) Extract them to a safe place.
03) Open the extracted folders and go into the Update folder
04) Replace the VERINFO.DAT with the above one.
05) Copy everything you extracted onto a clean 4GB+ SD Card which has been FAT32 Complete Formated
(make sure that the files and folders on the root of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif
06) Put it in your Car (with the engine running or on a charger etc)
07) The Pioneer will ask you if you want to run the update choose ((yes)) the device will reboot and start the update.
08) Wait untill the update is completed
09) Once completed, it may ask you to update again, if so, select ((No)).
10) If you want to update your Bluetooth firmware then, enter Bluetooth settings and update the bluetooth firmware.
I want to try to update the AVIC-F930BT which is in my father-in-law's car. But I don't want to brick anything, mostly because it's not my own car / navigation.
What I did so far: I've downloaded 3.4Gb maps from an .nzb file called "Repost Pioneer Avic 2013 EU Update F30 F930 F9310 F40 F940 F840 F8430" and from that spot I found this thread from which I downloaded only 1 file: VERINFO.DAT
The other files.....haven't been able to download them yet.
If I can download these files and I follow the exact steps from the first page of this thread (or the above post), will I succeed in updating the cards? And do I have to update the BT also? Sorry for asking, but I want to be sure before I start with something I haven't done before.
Dank voor de reacties!
