2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
By pug · Sep 18, 2013in Hacks/Mods💬 445 posts👁️ 226,654 views
Page 4 of 18
Posted Oct 01, 2013 · 21:50 UTC#76
SUCCESS ON F20 without any problems !!! PERFECT !!! many thx again,
Posted Oct 02, 2013 · 15:03 UTC#77
Success on Avic-F40BT  :!:
First I tried to backup my German languages files wit Condis Hack 2.21...
No good idea, stuck on Bootscreen.
Deleting PRGx.flg doesnt help.
Flashed Pioneer version update 4.01 and unit works again.
Made a SD card with 2013 EU update and Voice directory with the needed voice file inside.
Flashed.... All ok, no Voice Files lost  :-P
Thank you, small donation on the way ...
Posted Oct 02, 2013 · 15:27 UTC#78
hi, please help me, after update i dont have video dvd view,
sound is ok,
what is a problem?
Edited Oct 02, 2013 by arczi1000
Posted Oct 03, 2013 · 06:06 UTC#79
sound is ok,
what is a problem?
Have you checked your AV1 and Av2 settings. Please check that and choose between IPOD and VIDEO.
Regards
Posted Oct 03, 2013 · 06:10 UTC#80
The german files are avilable in the new update and no need to backup.
Where did you but them, are you sure that the files you but on the SD have been flashed, or only the original within the update were copied over?
Posted Oct 03, 2013 · 13:50 UTC#81
the 2013 update from the first post of this thread comes with only 7 TTS voices : CZC, ENG, FIF, GRG, HUH, PLP and TRT.
the german voice present in the update is the recorded one (which can't spell streets name), not the TTS one so, yes it needs a backup... unless you don't care loosing this fonctionality ;)
Posted Oct 03, 2013 · 14:22 UTC#82
Wow... I did not even know that this device can spell street names, my F9310BT never did that.
Can anybody share these extended TTS voices? I am especially interested in the German one.
Posted Oct 03, 2013 · 15:01 UTC#83
here you'll find all 18 Text To Speech voices... and a guide to install them on your device. ;)
Edited Oct 03, 2013 by frisk
Posted Oct 03, 2013 · 15:06 UTC#84
Thanks a lot!
Posted Oct 03, 2013 · 19:19 UTC#85
I'm trying to update with a 32GB SD card, and does not work on my avic F40BT
Posted Oct 03, 2013 · 21:53 UTC#86
mij f920bt no problem works perfect! Great job!
Posted Oct 03, 2013 · 21:53 UTC#87
Is it formated as FAT32? Please reformat an try again, complete format will be better, it takes longer but will be the best way. If it doesn't work, try with another 8GB SD or a Micro-SD with adapter. I had the same issue with 16GB, 8GB and 4GB SD, succeed only with 8GB Micro-SD (Sandisk).
Regards
Edited Oct 03, 2013 by Travolta
Posted Oct 04, 2013 · 16:36 UTC#88
Thanks, keep up the good work, it works fine on a avic F930BT.
Best Regards.
Posted Oct 06, 2013 · 10:32 UTC#89
Think I'm going mad but I've downloaded the 5 files and the crack. How do I extract the five separate files to make one file?.. If I try and and extract I'm getting 5 separate files with update etc.
Many thanks
Posted Oct 06, 2013 · 11:30 UTC#90
Install winrar, http://www.rarlab.com/download.htm , righ click on part1, and choose "extract here" or "extract to pionner 2013 update", and it will unpack all folders in 1 folder for you.
Posted Oct 06, 2013 · 11:38 UTC#91
SUCCESS ON AVIC-F30BT without any problems !!! PERFECT !!! many thx.
Posted Oct 06, 2013 · 11:42 UTC#92
As Saman said, or download 7zip its free and right klick extract here. Then you will have  UPDATE and FIRMWARE folders also CARDINFO.cif. But all these to the root of your SD-CARD.
Regards
Edited Oct 06, 2013 by Travolta
Posted Oct 06, 2013 · 11:48 UTC#93
Succesfull update on my F40BT. Great that I now have updated maps. The explaination here on how to do the update was excellent and I had no problem at all.
Thanks again!
(and I've donated of course....)
Edited Oct 06, 2013 by bsmile000
Posted Oct 06, 2013 · 12:29 UTC#94
Travolta, do you know maybe which version DB from NQ is inside, if i remember previous 2012 maps were 2011.Q3? Is now there maybe 2012.Q3 or 2013.Q1 NQ?
p.s.
for author of OP, you made mistake in writing instructions, wrote "route", instead files to be added on root of SD card :), probably you though root of SD CARD :).
Posted Oct 06, 2013 · 15:37 UTC#95
Seems to be 2013 Q1, new streets and points weren't available until November 2012, but now are available. I've noticed by my self.
 Thanks, will be changed.
Posted Oct 06, 2013 · 17:00 UTC#96
hi, guys. can anyone tell will this all work on f3210bt (or 320bt)?
Posted Oct 06, 2013 · 17:19 UTC#97
The updated works on my f920BT
But Bluetooth i got 3.11? Not 3.32? Did i do something wrong?
Posted Oct 06, 2013 · 17:21 UTC#98
to update BT, you must do it manually as it's independent from the map update.
go to th BT parameters and you'll find an "update" option...
Edited Oct 06, 2013 by frisk
Posted Oct 06, 2013 · 17:23 UTC#99
oke and then? Use the same files? From the first post?
EDIT:
I see it :-) ty, going to update this!
Edited Oct 06, 2013 by Fantasy-bart
Posted Oct 06, 2013 · 17:42 UTC#100
Yes, same update files contain files necessary for BT softw. update.
Seems
Nice news, 2012 were with very old db if i remember 2011.Q3, bad coverage, specially for EE. Hope now is better, i'm sure its better if inside is 2013.Q1.
Tnx for info!
Np ;)
Edited Oct 06, 2013 by saman
Page 4 of 18
