2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
By pug · Sep 18, 2013in Hacks/Mods💬 445 posts👁️ 226,654 views
Page 2 of 18
Posted Sep 21, 2013 · 09:26 UTC#26
I'm gong to try this on my F30 that's been updated so is the equivalent of an F40 in all but badged name  :blink:
I will see how it goes & if it's successful I'll make a donation to you  Pug :)
Has anyone who's done this update previously done Pionara's mod to remove the nag screen and if so did you have to reapply the mod or does it still work?
I'm just unsure as to where the mod sits... in the OS or in the Navigation app.
Andrew
Posted Sep 21, 2013 · 09:33 UTC#27
If you apply the update then using testmode to get the files back off then it's easy enough. Worked on my F930. No need to reapply the update as it's already been installed.
Just follow the instructions for the mods in their relevant threads but bear in mind all the offsets are different so read the instructions carefully. The file structures are the same so should be simple enough.
Posted Sep 21, 2013 · 10:22 UTC#29
Just updated the F940BT including the bluetooth update, everything is working 100% as far as i can see.
Tried some "unknown" adresses i noticed missing in the old version, they're on the map now.
Update time for the navi 25-30 minutes, bluetooth 4 minutes.
Donation is on the way
Thanks Pug!
Posted Sep 21, 2013 · 12:22 UTC#30
As a heads up for this update, use this post for the offset: http://avic411.com/index.php?/topic/35523-remove-caution-nag-screen-bypass-hack/page-7&do=findComment&comment=269273
And follow the instructions for the very 1st post for instructions.
Thanks Pug found the newer posts in the nag thread after I'd posted my query here... ready, fire, aim :rolleyes: always my trouble
However I'm currently planning to edit the Navi.exe in the installer which should mean I don't even have to go back in and fix... one AVIC brick in the making, I hope not as I have found the offset you kindly posted and the hex looks correct so will report back how I get on.
Andrew
Eeek get a message after the install has completed... wrong SD card insert correct card & continue
Well as predicted I have a brick... done a fresh download of everything and I always end up with the same error message re wrong SD card. Tried to reinstall my v4 but that won't run either now, not quite sure how to get back in to the unit but have my testmode SD card so will give that a try next. But if anyone has any ideas as to why this may have happened I'd be interested
So a note for anyone attempting what I foolishly did... Reading many of Pionara's posts I find you can't have any changed files within the updater. Part of the reason for my first failure, my subsequent failures were a result of a corrupt .rar file, this was compounded by my using a Mac with a windoze emulator to expand and create the update SD. Thankfully a fresh set of downloads and a reformatted SD have resulted in a successful map update. Now just the nag mod to apply tomorrow...
Edited Sep 21, 2013 by abre
Posted Sep 21, 2013 · 16:59 UTC#31
anyone know if the version 5 have improved reading files through usb? because I think it is or was very limited.
Posted Sep 21, 2013 · 20:29 UTC#32
What was wrong with USB? I never seemed to have any issues to be honest.
Posted Sep 21, 2013 · 21:07 UTC#33
what happens is that it reads all formats are limited. I think that is so very wrong. Chinese equipment read everything, so a great brand like pioneer should read all formats without restrictions
Posted Sep 21, 2013 · 22:25 UTC#34
Agreed. The F950DAB is worse. The amount of videos that the 930 read that the 950 doesn't is quite shocking. Biggest problem I think is the deal they've done with DivX probably means they're not allowed to support more than they do.
Posted Sep 23, 2013 · 08:47 UTC#35
Thanks for the update!
But I accidently lost my german TTS files... Is anybody able to upload them?
Thanks in advance
Posted Sep 23, 2013 · 10:17 UTC#36
Thanks in advance
senden Sie mir eine Nachricht und ich werde Ihnen sagen, wie es geht
send me a private message and I'll tell you how to do it
Edited Sep 23, 2013 by alexis99
Posted Sep 23, 2013 · 18:30 UTC#37
If you update to EU 2013 and your language isn't one of the five or six provided with this update, you'll loose your TTS files.
As for the precedent update, I can provide several lost TTS files for free for those who hadn't done a backup :
CZC, DAD, DUB, ENG, FIF, FRF, GRG, HUH, NON, PLP, PTP, SPE, SWS and TRT.
Just send me a PM...
EDIT : Now, there is DUN too... thanks to petergun! If you can send me the few missing ones (german, italian and romanian) it would be perfect and helpfull for the community.
Edited Sep 26, 2013 by frisk
Posted Sep 25, 2013 · 08:51 UTC#38
hello everyone how do I do x f9310BT update?
thanks
Edited Sep 25, 2013 by osso1976
Posted Sep 25, 2013 · 15:21 UTC#39
Where can I find this TTS files in device data files? I want to make backup of it, before I'll try this update
I have f920bt with 4.01 soft.
Posted Sep 25, 2013 · 15:21 UTC#40
they are in the ndata folder...
Posted Sep 25, 2013 · 21:54 UTC#41
update ok tanks
Posted Sep 26, 2013 · 17:58 UTC#42
Which are the languages provided in this version?
Posted Sep 26, 2013 · 18:37 UTC#43
the update comes with CZC, ENG, FIF, GRG, HUH, PLP and TRT.
So if your language is DAD, DUB, DUN, FRF, GED, ITI, NON, PTP, ROR, SPE or SWS you must back up your TTS files before updating...
you'll find them in NDATA/TTSData/
I can provide all of them except GED, ITI and ROR (always looking for them if you have them!)
Posted Sep 26, 2013 · 19:13 UTC#44
Im not sure how to get the Swedish TTs files from my F9310BT, but is it possible to get them from you and put  them in the installation folder before the installation?
If i look into the update/NDATA folder, there is no TTSData folder. Only 106 ndata files..
Or what is the best way?
Thanks for reply.
Posted Sep 26, 2013 · 19:25 UTC#45
you won't find them in the update!
you must get them from your avic with supertestmod (or just ask me for them...)
the swedish TTS files must be added after updating your avic by creating the following folder structure on a SD card :
VOICE\TTSData_SWS\
and copy the TTS files in the TTSData_SWS folder on the SD card, then insert the SD in your avic and install SWS with menus from regionals parameters.
you mustn't change anything in the installation files or the update won't work.
you can't copy manually TTS files directly in the AVIC with supertestmod or it won't work.
just send me a MP and I'll give you everything you need to do it yourself (TTS files, video tutorial...)
Posted Sep 26, 2013 · 20:22 UTC#46
Awsome! Thanks!
Posted Sep 26, 2013 · 20:38 UTC#47
check your inbox...
Posted Sep 26, 2013 · 22:39 UTC#48
Thanks pug/Pionara/Travolta/frisk! :)
Successfully updated AVIC F940BT (no hack/mod) from 4.01 to 5, also bluetooth from 3.24 to 3.32.
I now have addresses that were missing before.
Next I'll try the "warning nag" fix when changing to the navigation screen.
Posted Sep 27, 2013 · 09:20 UTC#49
many thx again to Pionara and Travolta ..
i have a question ...
i Remember last year i update correctly 1UNIT F930 AND 1UNIT F20
same card but i only change the cardinfo file ..
the question is :
AVIC-F30BT, AVIC-F930BT, AVIC-F9310BT, AVIC-F40BT, AVIC-F940BT, AVIC-F840BT, AVIC-F8430BT
KJJARRH8R51UX72EUR what units upgrade ?
X07EURX27EURX30EUR what unit upgarde ? -> i remeber last one upgrade the F10-F20-F920
i also have the tts files of last year from
radeonorama
its good also for this update ?
many thx in future (sorry for my english)
Posted Sep 27, 2013 · 11:21 UTC#50
the question is :
radeonorama
you've said, as you say it is.
Page 2 of 18
