AVIC-N4 bypass
By toddj85 · Sep 15, 2007in Hacks/Mods💬 100 posts👁️ 103,327 views
Page 2 of 4
Posted Oct 19, 2007 · 21:58 UTC#26
havent heard of it. did the wire come out of the back of the head unit?
Posted Oct 19, 2007 · 22:03 UTC#27
No it is still in the spot. Will try another unit just to make sure and re-do the mod for the unit.
Posted Oct 19, 2007 · 22:10 UTC#28
Then it was done wrong. The date has absolutely nothing to do with it
I have witnessed a AVIC N4 bypass that stopped working after 20 minutes of driving. Any ideas? I heard that the date of the software makes a difference.
Posted Oct 19, 2007 · 22:14 UTC#29
So should the wire be reinstalled in the "bypass spot" and then grounded along with the parking brake wire?
Posted Oct 19, 2007 · 22:29 UTC#30
That would be correct. Gold Star.
Posted Nov 01, 2007 · 01:02 UTC#31
Just wanted to add my two-cents worth on this subject. I searched and searched the web for all info I could find on the bypass. The only info out there as of Oct 30th was the info in this thread from AVIC411. I had my N4 installed yesterday and I have followed the bypass instructions from here. Just to let you all know, in case you are wondering or worried about doing it, mine works as shown. I pulled the yellow/black wire out of that connector (which was not being used and is listed as the "guide on" lead that controls the mute feature on the multi channel processor control unit that I do not have and will not be getting) and placed it in the open spot that is shown in the pictures. Once grounded out, along with the parking brake, I have what should be available to the user all the time. Thanks to those that worked on this, and those that took the time to post it properly. Thats why I took the time to answer back, so others know it works.
Posted Nov 17, 2007 · 00:09 UTC#32
Does Avic-N4 plugs (connectors) between head unit and brain are the same as all connectors on Avic-n2. I would like to change my N2 for N4 ... I just don't feel like running all the wires again.
Posted Nov 22, 2007 · 01:07 UTC#33
on my N1 i wired the parking brake wire to a switch so when it was on it would plas as if it was grounded and when it was off it would play as it should with the e-brake. i did this in case i got pulled over. now with the N4 woud i just ground the bypass wire and run the switch off the ground wire. or run both to the switch
Posted Nov 22, 2007 · 21:10 UTC#34
Pull over for what? If you watching movie while driving by yourself (which is not too smart to do) and cop pulls you over just hit Nav button and it will switch to NAv screen ... cops can't stop you for having your Nav on.
Posted Nov 30, 2007 · 08:19 UTC#35
On my N4 i just grounded the parking break wire for now, i was wondering if that will cause the nav to think i am not moving and therefore when i drive, the arrow on the nav won't move. can anyone confirm that's the problem?
Posted Dec 01, 2007 · 09:15 UTC#36
Nope, that means you have antenna issues.
Posted Dec 08, 2007 · 02:37 UTC#37
I know this has been beaten to death, but I really don't want to fry my new radio. I understand I need to ground the parking brake and 'magic' wire. However, I want to make sure I understand the 'magic' wire in the 'magic' hole. I understand that I can either cut/move the mute wire or just add a new wire to the hole in the picture. Is this correct? If not, please explain like you would to an 8 year old.
Remember, I'm an Aggie.
Posted Dec 08, 2007 · 02:48 UTC#38
Thats correct. It would be better to move the wire, rather than cut it, because the little metal pin will fit perfectly in the 'magic' hole and secure it properly
Posted Dec 13, 2007 · 02:59 UTC#39
I couldn't get the 'guide on' wire to go into the magic hole, so I just cut a new one, put it in, and made sure it was secure. I tapped this wire and the parking brake wire into the black wire that looks like it's supposed to be put under a screw. It's the same black wire that comes out of a 1X1X2 in box that also has the yellow battery wire.
Did I do everything correctly? Thx.
Posted Dec 16, 2007 · 20:28 UTC#40
Hi. I need to know. Which one of the openings is the bypass opening?
Most people remove an extra wire that they are not using (like the cell mute.) Insert that wire/pin into the "bypass" opening. Then ground the other end of that wire, and also ground the light green parking brake wire. Then you should be good to go
Posted Dec 17, 2007 · 02:12 UTC#41
The giant pictures on the first page of this thread didn't give you a hint?
Posted Dec 20, 2007 · 21:21 UTC#42
I just bought a brand spanking new n4 from pioneer (it was manufactured nov) and did the bypass and grounded the parking brake according to the picture. Heres the thing, then its stopped, the menu's and dvd video plays, but the second I go over 10mph, it cuts out video and navi buttons.
Think I should recheck the pin or pioneer has gotten smart/ changed something up?
Posted Dec 21, 2007 · 00:38 UTC#43
Check your install. The bypass works
Posted Dec 27, 2007 · 02:03 UTC#44
I finally got time to pull it out today. I found that iff you just strip the wire and jam it in there w/o using a pin it works better. Make sure you zip tie or tape it so it doesn't slide out than too.
Posted Dec 30, 2007 · 23:42 UTC#45
If you are ever having a problem getting the pin to stay in, use a drop(A DROP!!!) of CA Glue (super glue) w/ accellerator to lock pin in. I do that to every bypass I do. Works like a charm.
FYI: DO the glue AWAY from the unit!!!
Posted Jan 12, 2008 · 06:27 UTC#46
Thanks guys! I did mine here at the keyboard. Waiting to do my install.
Posted Jan 21, 2008 · 16:10 UTC#47
Rock on,I am looking at buying the N4 for my Mini Cooper S & this helped me alot.
joe r
Posted Jan 23, 2008 · 01:38 UTC#48
Ok, Dane186 I had the same problem as you. Well I still have i actually.I have a new AVIC N-4 from September 2007. What year is yours? I started to drive away and then it cut out on me and when I came to a stop the buttons and video came back. What should I see when I start up the unit?
Should I correctly connect the wires for the brake and then do the bypass? Or just do the bypass and that is that? I get the caution message that the brake wire was not properly connected. Will that message go away if I fix the bypass wire again?
Posted Jan 23, 2008 · 02:55 UTC#49
Ground the parking brake wire and ground the wire attached to the pin you moved
Posted Jan 23, 2008 · 17:00 UTC#50
my 2 cents...... i have a 98 lexus es300, the bypass works excellent
Page 2 of 4
