NEW Firmware for: x000 - ver:1.15/1.18, x100 - ver:1.10, x200 - ver:1.06/1.07
By asd255 · Jul 09, 2017in NEX Series💬 31 posts👁️ 16,776 views
Page 1 of 2
Posted Jul 09, 2017 · 06:21 UTC#1
NEW Firmware for AVIC\AVH x000\x100\x200 platforms
update: june 2017
Test Mode does not work with old keys
platform x000:
AVH-X8600BT - 1.15 download
AVIC-Fx6x EU5 верÑÐ¸Ñ - 1.15 - download
AVIC-Fx6x UW5 верÑÐ¸Ñ - 1.15 - download
SPH-DA120 EU - 1.18 download
platform x100:
AVH-X8700BT - 1.10 - download
AVIC-F970BT - European (EU) Model - 1.10 download
AVIC-F970BT - Russian (UR) Model - 1.10 download
platform x200:
AVH-X8800BT - 1.06 download
AVIC-F980BT - European (EU5) model - 1.07 download
AVIC-F980BT - Russian (UR) model - 1.07 download
Edited Jul 16, 2017 by asd255
Posted Jul 09, 2017 · 14:57 UTC#2
I come with the new firmware no longer in the Test mode menu ?!
I have a F88DAB/NEX8200 with new Firmware 1.07 :(
Is there a solution for this?
Edited Jul 09, 2017 by Handygamer
Posted Jul 09, 2017 · 17:04 UTC#3
downgrade
Posted Jul 15, 2017 · 21:29 UTC#4
Is the upgrade for x000 "safe" to use regarding map patch and smartphone / map confirm bypass?
Posted Jul 16, 2017 · 09:10 UTC#5
atm no. Think Pioneer have done something with the new firmware regarding testmode. Stick with the "old" one until someone else can confirm this.
Posted Jul 16, 2017 · 20:55 UTC#6
Thx :-)
Posted Jul 17, 2017 · 18:20 UTC#7
I'm a little confused... I don't plan on upgrading right away, but are any of these for the AVIC-8000NEX?
Posted Jul 17, 2017 · 19:50 UTC#8
For the x200, the latest version on the Pioneer site is 1.04.  How is it 1.06 here?
Posted Jul 20, 2017 · 10:58 UTC#9
Can someone confirm that the Crack Hack Patch is working with the new vesion 1.15?
Is there a changelog for 1.15?
Edited Jul 20, 2017 by Mod2Destroy
Posted Jul 21, 2017 · 04:18 UTC#10
atm you cant enter testmode to apply the patch with this update. so stick with 1.14
Edited Jul 21, 2017 by SpecTrax
Posted Jul 21, 2017 · 09:17 UTC#11
I readed this in your Post #5 and several times here.
The test mode is unimportant to me as long as I can update the maps. What should be useful in this?
Posted Jul 21, 2017 · 14:13 UTC#12
testmode(key) is needed if you are gonna update/copy maps to your unit. If you bought the maps, then no worry. Use naviextras. But if you downloaded them, you need the testmode-key to copy maps and patch the navsoftware.
Posted Jul 23, 2017 · 18:33 UTC#13
Newly signed up to the forum 8)  - I've just purchased a used f960bt (nex 6000) from ebay, all installed and working fine.... BUT the previous owner very kindly (in their mind anyway) decided to update to the latest 1.15 firmware before shipping it to me... so now none of the test keys work, and I cant run any of the stuff I intended to (like nav warning disable, patched nav maps).
Am I completely out of luck? Or is anyone planning on getting testmode working again?
Posted Jul 23, 2017 · 20:47 UTC#14
atm you just have to have alot of patience :) btw i think you can downgrade the unit to an older version, then the patch/crack will work.
Posted Jul 24, 2017 · 02:50 UTC#15
so even though it says platform x100AVH-X8700BT - 1.10
​and i have nex8100 latest update is 1.09 not 1.10
Posted Jul 24, 2017 · 11:37 UTC#16
You sir are a genius - I'd assumed it couldnt be rolled back (Pioneer website says you cannot) - downloaded the 1.14 from the link on this forum, fired it up on the headunit - got a warning it was older than current did I wish to continue, then simply said yes and installed 1.14 over the top! Had to do the bluetooth rollback too, but now working fine - testmode works perfectly, and I've patched out the annoying nav warning 'OK' screen  :-P
Posted Jul 24, 2017 · 18:54 UTC#17
You can get a complete System Dump from a previous version of the NEX 6000 to downgrade the Device.
Posted Jul 25, 2017 · 16:22 UTC#18
platform x200:
Is the 8200NEX different than the AVH-X800BT?  I'm just confused as to why this is firmware version 1.06 but the Pioneer web site only has version 1.04 for the x200 series.  Thanks for any help educating me.
Edited Jul 26, 2017 by cjust
Posted Jul 25, 2017 · 23:19 UTC#19
 will this work on the 4200?
Posted Jul 30, 2017 · 09:39 UTC#20
update: june 2017
platform x000:
platform x100:
platform x200:
New keys available for the new firmware
asd255 was so kind to share some Golden apples & eggs with us. The content he provided contained some different versions of testkeys. The one we need (i thnk) is the tech one, so this is the one im sharing.
Use the goldenapple.tst key with your preffered patch
pass: avic411
Hopefully admins/asd255 dont mind if i share this file,...otherwise please edit this post
GOLDENAPPLE.zip
Edited Aug 13, 2017 by SpecTrax
Posted Aug 04, 2017 · 11:25 UTC#21
anyone??
Posted Aug 07, 2017 · 18:47 UTC#22
anyone??
Also interested. Just downloaded frokm web and it says 1.05 is newest ver
Posted Aug 11, 2017 · 12:01 UTC#23
Replace the "old" tesmode_a.key with the goldenapple.tst
Dont replace or rename the file.
Just copy goldenapple.tst and then you can enter to Testmode.
Can confirm that v1.15 and Testmode is working.
Edited Aug 11, 2017 by Mod2Future
Posted Sep 07, 2017 · 23:42 UTC#24
pass: avic411
Can you please provide instructions on how to bypass OK Screen at startup using this Golden Egg? Did a quick search, can't find anything.
Posted Sep 08, 2017 · 04:34 UTC#25
only works on the x000 platform (incl. 5000-8000NEX/F960BT/F60DAB, AVIC-F960BT / AVH-X8600BT / SPH-DA120). Not on the x100!
pass: avic411
  • Download file
  • Unpack downloaded file(s) into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working).
  • Your device will reboot into testmode.
  • Select Write program forcedly => Copy Script, script will patch your system and reboot.
  • Remove USB stick after script finishes.
​NEVER ENTER COPY DEVICE MODE, YOU WILL BRICK YOUR DEVICE!
remove_pl_and_smartphone_OK_screen_x000.zip
Page 1 of 2
