Works fine with F-920BT...
thanks @RonS
thanks @RonS
Works on f20bt !
Ok, thanks for this topic, but where i can download map update now please ? thanks
Hope this thread isn't dead yet![]()
I have an F940BT with the original 04.000 firmware and original 2012 maps (I think, no map version shown).
Can I run the 'ShortFuseScript' without updating the firmware to Pioneers original FW_Update_v4.600 ?
On 11/26/2019 at 2:56 AM, piethorden said:Can I run the 'ShortFuseScript' without updating the firmware to Pioneers original FW_Update_v4.600 ?
why would you NOT want to update the firmware?
how long does it take to update from SD card?
15 minutes ago, sahblood said:how long does it take to update from SD card?
To install the hack? A few seconds. If your question is about installing the map update, it belongs in the map update thread. Should take around 20-30 minutes.
Hey,
I'm wondering if this hack is a one-time only install, or if it should be applied again before updating the maps again.
I used it for the 2017 update on my F920BT, but am now wondering if I should run it again when the 2019 update becomes available or if it's a persistent hack that gets preserved after a map+software upgrade.
8 hours ago, CoinCoin88 said:Hey,
If you ran it in 2017, it wrote the hacked RenewalIFLib.dll file in PRG0/APL and PRG1/APL. Only one of those files got overwritten by the 2017 update. When you install an update, it overwrites the "non-active" PRGn files with the new update's files. Then it makes the new PRGn the active directory by setting or deleting /USER/PRG.FLG. So I'd guess the hack needs to be installed again since the non-hacked one is in the "active" PRGn/APL
However, that's all just theory. No one that I know of has even tried the hack with 2019. So I guess we'll find out soon.
Hi,
where is topic for update maps 2017 please ? i need the script please, thanks you
Can someone send me a link to the shortfusescript.zip ? I cant download from this thread and I could not find anywhere else ?
1 hour ago, Onlineritter said:Can someone send me a link to the shortfusescript.zip ? I cant download from this thread and I could not find anywhere else ?
Nothing is wrong with the link. You have to be a registered member to access that file. Since you just joined, you can now download it.
Note: this seems to be a new requirement since only recently have people been complaining.
Yeah. You were right and thank you it worked.
grazie mille molto gentile
hey guys sorry for the long delay, may be 5 years too late, but here it is - v7 (2017) update VERINFO.DAT
hi,
the file is no longer available, could you please share it again?
18 hours ago, Firas said:hi,
First, its not clear what file you are referring to. Mine, or the pionara post immediately above yours. Regardless, the files are still available, but you must be registered to download files hosted on avic411. Since you are now registered, try again.
Anyone have a shortfuse hack?
The one on page 1 cannot be downloaded
7 hours ago, Eriiicsson said:Anyone have a shortfuse hack?
Yes it can. You just needed to be an AVIC411 member, which you now are.
Has anyone tried this on a F90BT? Thanks
