2017 v7 Mod: Nag Screen Removal Z, X, and F series
By RonS · Aug 19, 2017in Hacks/Mods💬 31 posts👁️ 15,615 views
Page 2 of 2
Posted Aug 20, 2019 · 18:09 UTC#26
On 1/13/2019 at 6:19 PM, QB89Dragon said:
For anyone looking to disable safe mode (soft parking brake hack) on the 2017 firmware, I've found the updated byte offsets when editing Navi.exe.
offset 0x15AF98 from 02 00 56 E3 to 09 00 56 E3.
offset 0x15AF84 from 01 10 A0 E3 to 00 10 A0 E3
This has been tested on an X9310bt.
Awesome! Is there an easier script version or step by step how to do this out there? I would like to disable safe mode but I'm a noob at this stuff and I'm concerned I might edit it wrong. I have the 2017 updated AVIC-X920BT.  Thank you!
Posted Sep 04, 2019 · 20:54 UTC#27
On 01/03/2018 at 7:38 PM, commando528 said:
In an attempt to give back instead of continually freeloading, here is a modification of RonS' ShortFuse script coupled to the patched Navi.exe in post #2 that was used successfully on a Z110BT after upgrading to the 2017 v7 US/Can Navi Maps.. .
    Instructions (almost verbatim, just copy&pasted with appropriate edits).  Held off directly attributing the post, lest anyone mistakenly tries to hold him liable:
"Here is the easy way to install the NoNag hack with no TestMode,  editing or patching involved.
Moderator note: WARNING: Only run this script if you are already running v7.0 firmware (2017 maps).  I did a binary file comparison between US and EU (v7.0) NAVI.EXE and they are identical. So these files may also work for F series units. Since the original files are copied to the SD, if there is a problem you can manually un-do this using TestMode. You could also copy the V7 NAVI.EXE from the 2017 update files.
Just download this attached zip, unzip, and copy the 3 files to the root of a blank fat32 formatted SD. When you insert it into your AVIC it runs a script that will backup both your existing Navi.exe files, then overwrite them with a patched one."
When you insert the SD, it will prompt you to press any key (button) to continue - or - turn off the ignition to abort.  If you decide to abort, just turn off and on your unit - then eject the SD. Nothing on your unit will have changed."
Same rules apply:
  • Contains the special scripting-specific version of TESTMODE.KEY
  • Deletes the TESTMODE.KEY immediately after initialization to avoid overwriting the original Navi.exe back-ups created on the SD from the unit itself (labeled Navi.ex0 & Navi.ex1), if the card is left in or reinserted again.
  • Can't hold me liable either.
Navi_NoNag_Script.zip
RonS & commando528
Just ran on my AVIC-X940BT unit and it worked! Thanks
(V 7 -- 2017 maps)
Posted Jun 01, 2020 · 04:33 UTC#28
Hello!!
@Rons
PLEASE ASSIST! :)
First of all, u rock as so does this website - its awesome. :cool:
Is there any mentioned mods/apps applicable for avic RZ-05?
Thank you,
Tim.
Posted Jun 01, 2020 · 12:39 UTC#29
13 hours ago, Easttimour said:
Hello!!
@Rons
PLEASE ASSIST! :)
Thank you,
Tim.
Sorry, I don't know anything about the MRZ series. I see lots of posts regarding them (mostly about changing the language), but it isn't an area of interest for me.
Edited Jun 01, 2020 by RonS
Posted Mar 15, 2022 · 01:54 UTC#30
I'm new here but I just wanted to say, if you're out there, thank you. To everyone who worked hard on this and all the other interceptions to reclaim property which is already ours. You guys are heros. Your labor is still being used and appreciated to this day. May fortune and prosperity find you happy and content. Cheers. -Nathan
Ps. Hats off to RonS. A more true hero there never was.
Posted Apr 25, 2023 · 14:43 UTC#31
AVIC-F840BT V7 works great.
Thanks.
Page 2 of 2
