Speedcams for F9310BT
By sheringham · Sep 30, 2017in Hacks/Mods💬 5 posts👁️ 2,190 views
Posted Sep 30, 2017 · 15:54 UTC#1
Has anyone an idea if this device supports speedcams - and if so if IGO speedcam files can be used ?
I have looked in different forums and I see that some users are mentioning thoose .txt files to be compatible ...
I have copied as suggested it to a SD card (FAT32 - default settings ) and to this path : F:\poi\speedcam\
But when starting the Pioneer nothing is loading ?
Is there anyone in here  that might know about this option ?
speedcam_DK.txt
Edited Sep 30, 2017 by sheringham
Posted Oct 01, 2017 · 13:06 UTC#2
The unit accepts speedcams but not on the way you added them, in the link http://s000.tinyupload.com/index.php?file_id=18892399194920218897 you can find a rar file and that's the way it works. Greetings from Holland
Posted Oct 02, 2017 · 08:16 UTC#3
OK - I will try that later - thnx for mentioning this Sjarrel  :smile:
I see 3 files from 2014 ?
Arent  there any newer once .
How to actually perform the update ?
Edited Oct 02, 2017 by sheringham
Posted Oct 04, 2017 · 19:14 UTC#4
Your welcome! and this is very old and i don't know if the update the speedcams. this was bought from poibase.com
Posted Oct 16, 2017 · 18:24 UTC#5
Hi, I can provide actual fixed speedcams (from POIbase) for F930BT/F9310BT... here
Edited Oct 16, 2017 by frisk
