Get your european fixed speedcams for AVIC-F920BT/F930BT/F9310BT/F10BT/F30BT here!
By frisk · Oct 16, 2017in Hacks/Mods💬 35 posts👁️ 14,273 views
Page 1 of 2
Posted Oct 16, 2017 · 21:55 UTC#1
Hi!
I can provide european speedcams (fixed only) from my POIbase account for F920BT/F930BT/F9310BT/F10BT/F30BT (and probably for other models but I can't test so just try and tell me if it's OK for your model...).
I use them since a few years and get sound warning when approaching a fixed speedcam. They also appear on the map.
First of all, try with your own country!
- download attached zip file and extract ;
- then extract your country zip file directly to your SD without modifying anything ;
- put SD in your powered-on avic, you should see a warning - accept the installation ;
- check if you can see a known fixed speedcam on your map (don't forget to set speedcams "on" in avic parameters!)
If it's OK then I can merge several countries for you but remember the more POIs you add, the slower your navigation will be (forget about getting all european speedcams, the max I tested without problem is FR+BE+NL+LU that's nearly 6000 POIs). I joined snapshot for each country with total speedcams so you can count by yourself to check if you stay under 10000 POIs (imposed limit by Pioneer). If you want to test more, do it at your own risk... and don't complain after!
Remember that speedcam warnings are forbidden in France and probably in other places...  :mrgreen:
fixed speedcams.zip
Edited Nov 30, 2017 by frisk
Posted Oct 17, 2017 · 20:03 UTC#2
thanks man
Edited Oct 17, 2017 by dxenos
Posted Oct 23, 2017 · 05:24 UTC#3
Hi, many thanks for your post, could you provide a merge with FR+SPAIN+portugal+andorre ? thanks in advance
Edited Oct 23, 2017 by saliphil
Posted Oct 23, 2017 · 17:50 UTC#4
@frisk
  I did try to follow your small guide , files are copied on the root of my SD card ( 4GB - Fat32)  But nothing is happening when I insert the card and AVIC F9310BT is turned on.
Also tried to start engine whilts card is in slot - same story.
I have the latest sw version 7.00 and the newest EU 2017 card . Used this 4GB card in the updating process , so its acually working .
Can you please guide me whats wrong ?
Thnx
Posted Oct 23, 2017 · 18:23 UTC#5
Hello
   avic f10bt updated 7.0
      speed cameras installed Spain
thank you very much
:razz:  :razz:  :razz:  :razz:
Edited Oct 23, 2017 by taek72
Posted Oct 25, 2017 · 17:42 UTC#6
Hi Frisk, thanks for your speedcams, could you provide a merge with Finlande + Estonie + Norvege + Suede, Thnx.
Posted Oct 29, 2017 · 11:45 UTC#7
@frisk - I managed to figure out now  how to do it :smile:
Thnx a lot !!
Edited Oct 29, 2017 by sheringham
Posted Nov 05, 2017 · 11:31 UTC#8
@saliphil & MikkoM :
Sorry for the delay, it was holiday time in France... ;)
See the attached files for requested packs : France-Espagne-Portugal-Andorre (5048 POIs) et Finlande-Norvège-Suède-Estonie (2777 POIs).
@sheringham :
I'm glad you manage to install by yourself.
@taek72 :
thanks for the feedback, I add F10BT to the compatibility list.
FR-ES-PT-AD-5048POIs.zip
FI-NO-SE-EE-2777POIs.zip
Posted Nov 05, 2017 · 17:24 UTC#9
@frisk, Thank you very much again!!  :cool:
Posted Nov 07, 2017 · 16:41 UTC#10
Hi Frisk, Many thanks.
Posted Nov 15, 2017 · 16:29 UTC#11
Hi,
thanks for the feedback, I add F920BT to the compatibility list.
:razz:
Edited Nov 15, 2017 by frisk
Posted Nov 28, 2017 · 20:12 UTC#12
Works on an F30BT with the latest 7.0 update.
Thanx.
Could you make me a file for PayBays + Allemagne + Belgium + Luxembourg
Posted Nov 30, 2017 · 07:56 UTC#13
Hi Rob,
thanks for the feedback, I add F30BT to the compatibility list.
Here is your file... ;)
DE-NL-BE-LU-7771POIs.zip
Posted Dec 04, 2017 · 14:22 UTC#14
Frisk,
could you please provide a version for German, Switzerland and Austria or let me know the trick how to merge the information for multiple countries?
Thanking you in advance  :???:
Thomas
Edited Dec 04, 2017 by mdpapth
Posted Dec 04, 2017 · 19:18 UTC#15
Hi Thomas,
there is no trick : you just have to pay and POIbase app will do it for you.
DE-A-CH-6359POIs.zip
Edited Dec 05, 2017 by frisk
Posted Dec 09, 2017 · 10:07 UTC#16
Thank you very much indeed  8)
Posted Jan 04, 2018 · 16:37 UTC#17
I can't find something for UK, Is it available? Maybe together with France
Posted Jan 06, 2018 · 14:48 UTC#18
Hi,
UK is the one called "Royaume-Uni"...
Posted Jan 07, 2018 · 08:47 UTC#19
Hi,
Many thanks, French? is of course not my language
Posted Jan 16, 2018 · 12:02 UTC#20
Turkey is also ok, thanks
Posted May 11, 2018 · 07:59 UTC#21
Thank you very much Frisk, it works very well on my F920BT - as a new one
Posted May 21, 2018 · 08:05 UTC#22
Hello I installed european fixed speedcams on my Avic F940BT and I work but unfortunately sends a signal too late only 100 m from the camera, how to set up to notify me early.
Posted Dec 01, 2018 · 18:52 UTC#23
aggiornamneti per italia?
grazie mille
Posted Jan 30, 2019 · 01:28 UTC#24
Hi, will speed cams work with the avic f970bt?
Posted Oct 24, 2019 · 07:00 UTC#25
Hello Frisk,
do you know if there is an updated version of the POIBase ? The method to generate these files is complex ? If not, could you share how you do that please ?
Thank you for your reply.
Page 1 of 2
