HI Installed the pioneer dmh c2500nex..Great stereo so far..Been reading about installing a backup camera..States connect the backup light power to the violet/white wire in the stereo harness (reverse wire)..When I check that violet/white wire (putting the vehicle in reverse), it shows power to that wire from the stereo (have 12 volt light, connected one end of light to ground in vehicle and then touched the violet/white wire in stereo harness in reverse). I'm using the idata harness and maestro RR to simply things.
So if that wire is hot in reverse, why do I need to send a signal from the reverse lights as stated in all packages if that wire already lights up when put in reverse. To me that would seem that the stereo already know that it's in reverse. If that's the case, can anyone identify the [placement for the camera wires. I believe it has a rack (which goes to the brown plug in stereo). Then there is a power and ground(can they be connected at stereo) and finally what wire connects to reverse or maybe I don't need to connect to violet/white. or could I connect the power to the violet white and that would supply power to the camera
Any help would greatly appreciated
Cheers
Al
Calgary, Alberta, Canada
