New Release F20BT F30BT F40Bt F920BT F930BT F940Bt F840BT Etc 2019
By godzilla · Sep 07, 2019in Hacks/Mods💬 236 posts👁️ 197,668 views
Page 1 of 10
Posted Sep 07, 2019 · 23:47 UTC#1
Okay two years and another release for all these machines. Last time i bought the software and spread the wealth this time i need help as my situation has changed . I firstly need to  buy the software with the highest donator getting the original pack and the unused key, Everybody else will get the software for free every Euro , Dollar or pound will help my payal me address is
paypal.me/salsatnav
I will keep you in the loop with daily updates till we reach £125 then i will post it here  for FREE have a feeling Rons Shortfuse hack will do it again
Lets all help each other
Edited Sep 07, 2019 by godzilla — Reason: spelling mistake doh!
Posted Sep 09, 2019 · 11:28 UTC#2
donated.
Posted Sep 21, 2019 · 23:20 UTC#3
On 8/9/2019 at 1:47 AM, godzilla said:
paypal.me/salsatnav
this link paypal don't work,  how can i make the donation?
Edited Oct 03, 2019 by frankovskij
Posted Sep 26, 2019 · 18:48 UTC#4
Donated.
Posted Sep 29, 2019 · 17:55 UTC#5
Done!
Edited Sep 29, 2019 by seth_space — Reason: removed name
Posted Sep 30, 2019 · 19:05 UTC#6
Donated
Posted Sep 30, 2019 · 23:58 UTC#7
Under general in the topic:
2019 Maps (announcement only)
@spoon1 mentions he has the 2019 update.
@godzilla contact @spoon1
Posted Oct 03, 2019 · 22:42 UTC#8
Posted Oct 04, 2019 · 22:06 UTC#9
it worked for me:
paypal.me/salsatnav
http://paypal.me/salsatnav
Posted Oct 06, 2019 · 09:57 UTC#10
@Spoon is there some realse from you ? i have the 2017 maps, but there is so mutch change here .
Posted Oct 06, 2019 · 13:03 UTC#11
wow! is that also for F9220BT? where can i find it @spoon1
Edited Oct 06, 2019 by brommie
Posted Oct 06, 2019 · 13:54 UTC#12
@brommie The F9220BT (same as F920BT but for VW group dashboard)  you have is MY09-10 and the update @spoon1 has is MY11-12.
If @spoon1 shares the update the CARDINFO.CIF needs editing to be able to update your or others model MY09-10, but with previous updates this has been a succes already so it is normally possible if the needed changes for CARDINFO.CIF are found!
The same goes for the nag screen hack (to skip OK prompt warning on startup for navigation) that will also need to be found again (the correct hex adresses that need to be edited)
Edited Oct 06, 2019 by Pioneer snow
Posted Oct 06, 2019 · 19:32 UTC#13
Are you sure he has MY11-12 maps? All spoon1's previous requests for updates were for an F950-BT, which is MY13. That unit's hardware is not compatible with the earlier units. He has never posted exactly what firmware he has and that splash screen doesn't indicate a model.
Seems to me he is being intentionally vague and since he is not posting a link, it sounds like he's attempting to sell the update.  All this could easily be clarified by a short post from him.
Edited Oct 06, 2019 by RonS
Posted Oct 06, 2019 · 20:34 UTC#14
On 5-10-2019 at 8:19 PM, spoon1 said:
i have europe 2019 my11/12 edition update ...tested and works with testmode unlock password
@RonS I suppose he has MY11-12 based on @spoon1 his own message..., but indeed all this could be clarified by/from @spoon1 himself.
Posted Oct 06, 2019 · 21:32 UTC#15
Good. I somehow missed seeing that. If it is, it should also work for the x10-x20 models with the correct CardInfo.cif from previous years.
Posted Oct 07, 2019 · 10:42 UTC#16
Look to the lower left corner of the image he has posted. It says "AVIC-F40Bt"
Posted Oct 07, 2019 · 12:11 UTC#17
Good eyes. That just shows as a blurry smudge on my monitor. Zooming in two levels and I can just barely see something that resembles AVIC-F40BT.
I'll stay out of this unless things get out-of-control. I don't have any use for EU maps regardless.
Edited Nov 05, 2019 by RonS
Posted Oct 07, 2019 · 14:07 UTC#18
17 minutes ago, spoon1 said:
i have maps for my2011/12 and i can post CARDINFO, no problem !
so if you can modify my cardinfo then i can use the same maps to update also my201/09 ?
i mean maps are the same ? my2009/10 and my2011/12 ?
who can change my cardinfo, so i can try into my other pioneer , let me know
You can just use the cardinfo for your model from the 2017 update.
Posted Oct 07, 2019 · 15:17 UTC#19
47 minutes ago, spoon1 said:
sure that's all ?
maps are the same ?..for my2010/09 and my2011/12 ?
No, I'm not sure since I don't have an F-series. Just an educated guess. Every other update since 2010 (that's when I bought my Z110-BT), the maps were the same. The cardinfo.cif file controls what models get updated. If the cardinfo isn't correct for your headunit, nothing will happen when you insert the SD. Note that it isn't just the map files that get updated. The application files also change. However, there is a minor difference between the various models.
Just to be clear:
  • What is the Product number for the map update you have?  To see, go to the unzipped file folder and open UPDATE/ALLDATA.HTM
  • What actual AVIC model are you trying to install it on. The MY nonsense just gets people confused. Most don't even know what MY is. Your photo shows an F40BT, is that your unit?
Edited Oct 07, 2019 by RonS
Posted Oct 07, 2019 · 18:15 UTC#20
yes i have F40BG and a F10BT
So are you saying that you have already  installed 2019 on the F40BT and you want to also install it on the F10BT? If so, try this cardinfo.
Cardinfo for F10 and F20
Posted Oct 09, 2019 · 17:07 UTC#21
Donated.
Posted Oct 10, 2019 · 16:37 UTC#22
Donated.
Posted Oct 10, 2019 · 20:27 UTC#23
On 5/10/2019 at 12:06 AM, seth_space said:
it worked for me:
paypal.me/salsatnav
DONATED!
Edited Oct 10, 2019 by frankovskij — Reason: error
Posted Oct 10, 2019 · 21:27 UTC#24
Okay Guys to give you a total of who has generously donated and how much here we go:) Incidentally thanks everyone who has donated so far we are nearly there :)
  • Nicki C                                   15.00
  • dcams01                               10.00
  • Eberhard H                              5.55
  • Thorsten S                              8.88
  • Ed Van D                                10.00
  • Maurizio N                             10.00
  • Davide G                                   8.00
  • Hennadii V                              10.00
  • Franco A                                   7.00
  • Godzilla (ME )                        14.00
Big Thank you so far we have a total  98.43 Very nearly there ! if I have missed anybody out please let me know looks likely we will be able to be able to get the software very shortly currently Nicki is in the lead to receive the unregistered pack. Well done everybody - Godzilla
Edited Oct 11, 2019 by RonS
Posted Oct 11, 2019 · 04:58 UTC#25
On 9.10.2019 at 7:07 PM, supergecko said:
Darowizna
Darowizna
Darowizna-Donated 10
Edited Oct 11, 2019 by bubuu77
Page 1 of 10
