GEX-P7000TV
By Xartni · Oct 10, 2007in General💬 2 posts👁️ 922 views
Posted Oct 10, 2007 · 02:31 UTC#1
Ok, so I pulled the trigger on the GEX-P7000TV with the intentions of using it with the AV Input on the Z2. I was planning on it to be the solution I needed with the additional inputs for the PS2 and Ipod Video.
I was stoked to see that you can use the remote to switch the inputs. However, I searched around and did not realize I need an additional eye and controller. Can someone tell me if this is all I need?
http://parts.pioneerelectronics.com/par ... um=CXB4141
As an alternative, can I hook up the IP Bus cable, use the remote to choose the source/tv station and then switch over to the AV Input?
Sounds confusing, I know.
I know it can be modified per this post, but using the remote and and the AV Input would be fine for me.
http://avic411.com/forum/viewtopic.php? ... 0&start=15
Thanks in advance.
Edit: OK, I just found out that is the remote control, not the eye. Does anyone know where I can get an eye for this tuner?
Jason
Posted Oct 10, 2007 · 20:14 UTC#2
If you get desperate, here's a site with a schematic to make your own IR sensor:
http://mywebpages.comcast.net/boom3/
That schematic is actually a little over-complicated since you wouldn't need the LM1881N chip nor the resistors and capacitors attached to it. Basically you'd just need 2 parts, the IR detector and voltage regulator. It's something you'd have to build and probably cut/splice an RGB cable to connect it, so it's like I said... if you get desperate!
Although... you might have to build it because I seem to recall the IR sensor was built into the monitor.
If you hook up the IP-Bus cable, I don't think you can change the source of the 7000TV with the Z2's touchscreen controls. I could be wrong, but I don't remember seeing that option. The AV-Bus connection on the HU has an IR remote output you can possibly use on the 7000TV: REMOUT pin 10. That should allow the remote to work, but it might only work in Standalone mode (no IP-Bus control).
