4400NEX - LCD Broke or SD Card reimage?
By dj lpm · Apr 18, 2021in NEX Series💬 10 posts👁️ 1,222 views
Posted Apr 18, 2021 · 18:50 UTC#1
Is this the LCD or do I need to reimage SD?
Been working fine for two years and just started derezzing.  I checked wiring and couldn't find a loose connection or anything.
Thx in advance.
dj lpm
Posted Apr 18, 2021 · 19:52 UTC#2
What was done to the radio when it got a result screen. Was the radio taken apart??
Posted Apr 18, 2021 · 20:36 UTC#3
No.  It started doing this in dash.  Only thing I did was take it out of dash to diagnose.
Posted Apr 18, 2021 · 21:17 UTC#4
check the ribbon cable
Posted Apr 18, 2021 · 21:31 UTC#5
Thanks.  Will do.
Posted Apr 18, 2021 · 22:51 UTC#6
@boneeI tried reseating 60 pin on display side...no luck.  Ive removed screen from slide and popped open screen case.  48 pin from mobo to lcd looks ok.  Anything else specific to look at?  I have not opened box yet.
Posted Apr 18, 2021 · 23:56 UTC#7
clean faceplate pins
Posted Apr 18, 2021 · 23:59 UTC#8
Will do
Posted Apr 19, 2021 · 01:10 UTC#9
@bonee worked!  Thanks so much!!!!
Posted Apr 19, 2021 · 01:34 UTC#10
no problem
