Okay, so I posted this thread a while ago:
http://www.avic411.com/forum/viewtopic. ... celeration
and I thought I had the problem solved. However, when I added a subwoofer to my trunk, the extra power draw from the amp made the alternator noise more audible through the front left speakers (or I started getting picky with the noise). Today, when I installed the I-200 Ipod connector (which works) I grounded both the AVIC ground and what I think is the amp ground to the negative battery terminal directly. The sound is worse now. This is installed in a 2001 Lexus IS300, and it was self installed, following a detailed walkthrough made by a forum friend.
I used the Metra Toyota Interface (TYTO01) and followed these instructions:
The actual AVIC install: http://www.isfanatics.com/forums/showthread.php?t=230
This thread shows how to make the TYTO01 work correctly with a 2001 (they changed wiring in 2002+ models I hear) : http://my.is/forums/f103/2001-metra-tyto-01-harness-how-338386/
I don't really know what I was doing through this install.. I only know a little bit about this kind of stuff. I do know that the two wires I grounded to the negative battery terminal were in this part of the instructions (the first link given, to see pictures):
"A. The power connector bundle.
-Connect the RED wire from the 12 pin harness of the Metra to the RED wire labeled ACC on the unit.
-Connect the YELLOW wire from the Metra to the YELLOW wire labeled +BATTERY on the unit.
-Connect the BLACK wire from the Metra to the BLACK wire labeled GROUND on the unit. "
I realize this is a really long thread post, sorry for that, I'm just trying to be thorough. I hope the solution is easy! Any help is greatly appreciated ![]()
-Andrew
