Noise, computer maybe?
By rrmccabe · Dec 02, 2007in Problems/Troubleshooting💬 33 posts👁️ 4,099 views
Page 1 of 2
Posted Dec 02, 2007 · 21:18 UTC#1
This isnt an issue with the Z2 but I have noise in my speakers when no audio is coming from the headunit.
I think its picking it up on the low level RCA cable(s).
I have monster cable preamp running from the Headunit to the amp in back of truck (trailblazer). This is the 3 pairs in one cable type.
I can unplug the RCAs from the amp and it stops.
The noise is pulsing and has somewhat of a pattern. I am pretty its computer noise.
Any suggestions?
Posted Dec 03, 2007 · 00:39 UTC#2
did you run yor rca's and power cable down the same side of the car?
Posted Dec 03, 2007 · 03:47 UTC#3
Nope. I ran my 4 gauge power down drivers sill plate and RCA's down passenger side. Both sides have looms from the factory though.
Posted Dec 04, 2007 · 01:09 UTC#4
I read a lot on caraudio.com and it sounds like Pioneer is really bad about ground loops.
I made this cable (the wire goes to sheild) and installed it in just one of my RCA lines and noise went away. I still get a few odd noises on and off from heated seats, etc. I plan to do the other 5 !
Posted Dec 04, 2007 · 02:16 UTC#5
can you post a link to the tread @ caraudio.com please
Posted Dec 04, 2007 · 02:48 UTC#6
Sure, there are several, but this is a long thread and you will see a lot here.
http://www.caraudio.com/forum/showthread.php?t=198477
Just finished three more. I am not going to worry about subs.
Posted Dec 04, 2007 · 02:58 UTC#7
I'd send the unit back....Mine doesn't have it.
the only noice I ever hear out of my AVIC is the cooling fans, especially during a phone conversation...and that's really only with the engine off(loud ass GM 6L w/ dual magna's)
Posted Dec 04, 2007 · 03:40 UTC#8
are u using an AMP ???
Posted Dec 04, 2007 · 03:41 UTC#9
ummm do u think you can make 2 harneses like that for me :roll:
ill pay you
Posted Dec 04, 2007 · 04:35 UTC#10
Yep, I am sure I can.
Its a lot easier than soldering to the connectors like they were doing on that site.
Posted Dec 04, 2007 · 06:07 UTC#11
sweet whats the charge :D
Posted Dec 04, 2007 · 15:19 UTC#12
Something you might consider is this.
http://www.audio-discounters.com/310-460wh.html
I would have went this route but did not want to wait. Remove the plastic and add a ring terminal around it and tighten nut.
I think this was a better setup but cant find locally.
Posted Dec 04, 2007 · 16:20 UTC#13
cheapo 1000w US Acoustics for subs only.
Factory Bose amp
I'm assuming my PAC adapter(for Bose amp) filters the noice?
Posted Dec 04, 2007 · 17:28 UTC#14
and what is the point of that part ?
Posted Dec 04, 2007 · 18:02 UTC#15
Same thing as what I did. Allows you to ground the sheild of the RCAs at the head unit end.
In this case you would just remove the plastic piece shown in that picture and use a ring terminal liks this http://tbn0.google.com/images?q=tbn:lL7 ... rminal.jpg
Posted Dec 04, 2007 · 20:38 UTC#16
so insert that ring terminal where that plastic clip is ?
Posted Dec 04, 2007 · 21:08 UTC#17
Yes. As I said this would have been my choice but my noise was bad and I did not want to wait.
Works awesome. There are literally hundreds of post on the other site about this. But they are all hacking and soldering. This is easy and clean.
Below is rough drawing of what to do.
Posted Dec 04, 2007 · 21:19 UTC#18
that is awsome
but only 1 problem they dont ship to canada :(
and i was looking on ebay and cant find the rite one
if you have time can you check ebay maybe you will have better luck then me
Posted Dec 04, 2007 · 21:32 UTC#19
that is awsome
Try these guys. http://www.ambientweather.com/db310460wh.html
If not, do a search for 310-460WH on Google. Lots of places sell them.
Posted Dec 04, 2007 · 22:00 UTC#20
wow they all want $40 shipping and thats to USA only :shock:
im scared to ask for s&h to Canada
Posted Dec 05, 2007 · 00:26 UTC#22
Whaaa ur the best :)
Posted Dec 05, 2007 · 00:31 UTC#23
FARK
so while a i was clicking away they sold out :(
Posted Dec 05, 2007 · 02:39 UTC#24
FARK
Still 7 left. You need what.... 6 max?
Posted Dec 05, 2007 · 06:53 UTC#25
12
i have 2 avics 8)
Page 1 of 2
