impalassdude Posted December 29, 2007 Report Share Posted December 29, 2007 does anyone know the colors for hooking up the speed wire and reverse in a impala ss? can the speed wire be hooked up to tach wire? thanks Quote Link to post Share on other sites
blackbox Posted January 6, 2008 Report Share Posted January 6, 2008 yes, run the wire from the tach and it'll work. Quote Link to post Share on other sites
cntrylvr79 Posted January 6, 2008 Report Share Posted January 6, 2008 Yeah it'll work great. As soon as you start the car the avic will think you're moving. And if you rev the engine forget it. It'll think you're doing mach 1. What year is the impala? Quote Link to post Share on other sites
impalassdude Posted January 6, 2008 Author Report Share Posted January 6, 2008 its a 94...the 95,96 had it in the radio harness but 94 never had that feature.i was told it a green with white strip.but where?? thanks Quote Link to post Share on other sites
cntrylvr79 Posted January 6, 2008 Report Share Posted January 6, 2008 Here's what I have for a 94 impala. Speed Sense GREEN/WHITE DRIVER FRONT QUARTER BLACK 32 PIN CONN.POS B-8 Reverse Lights LIGHT GREEN (+) AT GEAR SELECT SWITCH My guess this is either at the shifter or the trans. If it's at the trans, then it might be easier for you to just run back to the taillights and tap there. Quote Link to post Share on other sites
impalassdude Posted January 6, 2008 Author Report Share Posted January 6, 2008 thanks for the help. the black 32...is that the pcm plug? Quote Link to post Share on other sites
cntrylvr79 Posted January 6, 2008 Report Share Posted January 6, 2008 I would venture a guess that yeah it would be the pcm. Quote Link to post Share on other sites
blackbox Posted January 6, 2008 Report Share Posted January 6, 2008 i wired it to my speedometer tach and it works great. Quote Link to post Share on other sites
cntrylvr79 Posted January 6, 2008 Report Share Posted January 6, 2008 Ok whatever you say. Quote Link to post Share on other sites
impalassdude Posted January 6, 2008 Author Report Share Posted January 6, 2008 I'm going with batman on this one.i have been told the same thing by several people NOT to use the tach wire.it will work but will not be accurate. Quote Link to post Share on other sites
