dcarrington01 Posted July 28, 2006 Report Share Posted July 28, 2006 I am goign to be installing my Z1 this weekend, and the wiring harness and everything will be here tomorrow (including the SMinntech mod). My question is this: I think I have the right place to connect the speed sense wie, but if someone who has installed it could see if I am on the right track! I was going to hook it up to the speed control line that goes to the speedometer cluster and the skid control actuator where the wheel speed sensors are. I have a diagram I can email if you woudl like to see it, since I cant post it here! Thanks! dc Quote Link to post Share on other sites
Dend Posted July 28, 2006 Report Share Posted July 28, 2006 Here is an easier place to find your VSS wire. Its at the fuse box inside your vehicle it is in the rear 4 pin plug pin one color is purple with a red stripe. Or you can go to your ECM (Engine Control Module) it is in the second plug from the bottom in pin 8. The ECM is located behind the glovebox Good luck and enjoy Quote Link to post Share on other sites
