I think you have the correct disc set. Your problem may be a settings issue or an install problem. Here's how to know.
Hit the Menu button on the left of the unit.
Make sure you are on the Navi screen and press SETTINGS.
Press VOLUME.
You should see voice volume (several levels available) and beep volume (sadly, only 4 levels.)
Adjust the volume levels to your likeing for each.
If the volume levels look good there, you may have an install issue. Swap the front and rear outputs from the radio and see if it corrects the problem.
Hope this helps.
