Tuning Haus Posted February 16, 2008 Report Share Posted February 16, 2008 sorry if this is a newb question but i was wondering if anyone can point me in the right direction or help me with the install for the BLUETOOTH in my Pioneer Z1. i was looking to purchase the bluetooth unit from Ebay... (do you guys recommend that or no?) i think they were around $80-120 i'm a very DO-IT yourself guy and althought i don't have much experience with audio/stereo stuff, i feel pretty confident with some direction i can get it done. how much is it to have the unit install anyway? it works with the z1 AND z2 units the same way right? thanks for any help in advance! Quote Link to post Share on other sites
mrgoodbar67 Posted February 16, 2008 Report Share Posted February 16, 2008 ebay is good. i bought a btb200 for cheap and installed it in 20 min. really easy. as a matter of fact i installed my whole d3, nav traff xm unit and ipod thing myself and i never had car electronics experience. cheaper to diy than at a shop. i think the d3 bluetooth install is similar to the z series install Quote Link to post Share on other sites
whtcrxghst Posted February 16, 2008 Report Share Posted February 16, 2008 The install is actually easier than most models. Just buy the NDBT1, pull the deck out, and plug in the NDBT1 to the bluetooth hookup. Thats it Quote Link to post Share on other sites
Tuning Haus Posted February 16, 2008 Author Report Share Posted February 16, 2008 thanks guys, i think i will get the ND BT1 unit. silly question, but how do you take the face place out? so it's just ONE wire that connects the Bluetooth unit to the Z1 unit? it gets the power on fed through that wire as well? Quote Link to post Share on other sites
JLeach12 Posted February 16, 2008 Report Share Posted February 16, 2008 yeah u just plug in the bt unit wire and secure it behind the dash....couldnt be easier what kind of car? it helps to tell u how to disassemble the dash Quote Link to post Share on other sites
Tuning Haus Posted February 16, 2008 Author Report Share Posted February 16, 2008 i have a 93 toyota land cruiser so basically i have to get behind the deck? so the dash must come out? Quote Link to post Share on other sites
blackbox Posted February 16, 2008 Report Share Posted February 16, 2008 i had to run a power and ground wire to the the btb unit. you just have to tap the wires onto the power and ground wire from the btb wire to the pioneer radio harness power and ground wires. be careful! Quote Link to post Share on other sites
inferno999 Posted February 16, 2008 Report Share Posted February 16, 2008 i had to run a power and ground wire to the the btb unit. you just have to tap the wires onto the power and ground wire from the btb wire to the pioneer radio harness power and ground wires. be careful! That's because you're using the CD-BTB200, which runs on the IP BUS. The Z-series has it's own special bluetooth adaptor ND-BT1, which simply plugs into the back, one cable, one connection, no need to splice anything =D Quote Link to post Share on other sites
Tuning Haus Posted February 17, 2008 Author Report Share Posted February 17, 2008 i had to run a power and ground wire to the the btb unit. you just have to tap the wires onto the power and ground wire from the btb wire to the pioneer radio harness power and ground wires. be careful! That's because you're using the CD-BTB200, which runs on the IP BUS. The Z-series has it's own special bluetooth adaptor ND-BT1, which simply plugs into the back, one cable, one connection, no need to splice anything =D sweeeeet! sounds easy enough!!! to take the head unit out or get behind it, would it be best to take the dash apart around it? i dont know if it's easier to access it by taking the head unit out or not? Quote Link to post Share on other sites
tcm004 Posted February 17, 2008 Report Share Posted February 17, 2008 i was thinking it would just pulg into the nav/xm tuner Quote Link to post Share on other sites
whtcrxghst Posted February 17, 2008 Report Share Posted February 17, 2008 Guess its a good thing they come with instructions i was thinking it would just pulg into the nav/xm tuner Quote Link to post Share on other sites
gaiex Posted February 27, 2008 Report Share Posted February 27, 2008 i had to run a power and ground wire to the the btb unit. you just have to tap the wires onto the power and ground wire from the btb wire to the pioneer radio harness power and ground wires. be careful! That's because you're using the CD-BTB200, which runs on the IP BUS. The Z-series has it's own special bluetooth adaptor ND-BT1, which simply plugs into the back, one cable, one connection, no need to splice anything =D Do we get the same functions with the BTB200? I want to buy an Bluetooth interface but the ND-BT1 its not available in Europe any more! When I go to the Z2 product information it shows BTB200 as an option! Do we will have the phone menus and etc? Quote Link to post Share on other sites
whtcrxghst Posted February 27, 2008 Report Share Posted February 27, 2008 The BTB200 does not work correctly with the Z series in the US Quote Link to post Share on other sites
gaiex Posted February 27, 2008 Report Share Posted February 27, 2008 The BTB200 does not work correctly with the Z series in the US Can you explain better what could be the problem?! Quote Link to post Share on other sites
gaiex Posted March 1, 2008 Report Share Posted March 1, 2008 It looks like that the bluetooth module ND-BT1 its not sold separately in Europe (they are part of the package with an new HD3BT unit), Can I buy a ND-BT1 from the states, are they the same!? Thanks Quote Link to post Share on other sites
