99silverbullet Posted March 19, 2008 Report Share Posted March 19, 2008 Hey everyone, I'm trying to upload screen savers, pics for my backwall on my D3. I've done everything possible. I created a cd with a file called pictures like the manual says and even tried creating a duplicate nav dvd with the pictures replaced with my new ones. Please HELP!!! Quote Link to post Share on other sites
HiFiSi Posted March 19, 2008 Report Share Posted March 19, 2008 If you do it exactly as it says, there's no reason it shouldn't work... Create a folder on your desktop named PICTURES. The pictures used should be 500x240 pixels, in jpeg format, and contain only letters and numbers in the file name (don't use spaces in the file name just to be safe) There can be no more than 20 TOTAL files inside the PICTURES folder. And the total size of that folder HAS to be over 1.8MB... you can use a large filler file in place of one of the 20 pictures in the folder to get it over that mark. Once that is all done correctly, burn that folder to a blank CD in DATA DISK mode. If all that is done correctly, it will work. I've done exactly that numerous times and it's worked every time. http://www.avic411.com/forum/viewtopic.php?t=12163 Quote Link to post Share on other sites
99silverbullet Posted March 19, 2008 Author Report Share Posted March 19, 2008 thanks so much, i will try it that way..i've done everything you said except make a folder on the desktop..i created one in my documents..i'll keep you posted. thanks! Quote Link to post Share on other sites
installermarc Posted March 19, 2008 Report Share Posted March 19, 2008 One thing HiFiSi forgot to mention (I know, the world is coming to an end. How could he ever forget this ) is to NOT use Windows to burn the disk. Use Nero or some other CD Creator program. Quote Link to post Share on other sites
99silverbullet Posted March 19, 2008 Author Report Share Posted March 19, 2008 If you do it exactly as it says, there's no reason it shouldn't work... Create a folder on your desktop named PICTURES. The pictures used should be 500x240 pixels, in jpeg format, and contain only letters and numbers in the file name (don't use spaces in the file name just to be safe) There can be no more than 20 TOTAL files inside the PICTURES folder. And the total size of that folder HAS to be over 1.8MB... you can use a large filler file in place of one of the 20 pictures in the folder to get it over that mark. Once that is all done correctly, burn that folder to a blank CD in DATA DISK mode. If all that is done correctly, it will work. I've done exactly that numerous times and it's worked every time. http://www.avic411.com/forum/viewtopic.php?t=12163 You are the man! Yah it worked and looks awesome, thanks for your help. Quote Link to post Share on other sites
