euphoria Posted August 6, 2006 Report Share Posted August 6, 2006 hi, if ducatiboy circuit is installed than can we also change the navigation location or destination while in motion as some people write that you can select a different location unless you stop the car and pull the handbrake and than select again a different location. any feedback will be highly appreciated,. thanks Quote Link to post Share on other sites
ducatiboy Posted August 6, 2006 Report Share Posted August 6, 2006 [quote name="euphoria"]hi, if ducatiboy circuit is installed than can we also change the navigation location or destination while in motion as some people write that you can select a different location unless you stop the car and pull the handbrake and than select again a different location. any feedback will be highly appreciated,. thanks[/quote] Yes, you can do anything while in motion... absolutely everything. There is a feature where you can change the location, this corrects for errors in the positioning. I wouldn't do that while moving, it will just mess up your location. Not that you can't, but it's not a good idea unless you aren't moving. If you mean you want to enter a new destination or what ever, sure. With my circuit you can do absolutely everything the Z1 can do while moving. Quote Link to post Share on other sites
