bbyers Posted April 5, 2008 Report Share Posted April 5, 2008 im alittle confused, if i connect the camara to my backup lights, i am under the impression that camara will come on when i put vehicle in rev, but what happens if i am going down the road while in navi mode and hit map and than camara will that also turn on camara? if not what is that button for, thanks for any help Quote Link to post Share on other sites
wgm5286 Posted April 5, 2008 Report Share Posted April 5, 2008 if you want to watch your camera while going down the road, you will have to wire the camera power source to an always on power source. I did that with my boyo and it works fine. Quote Link to post Share on other sites
bbyers Posted April 5, 2008 Author Report Share Posted April 5, 2008 if you want to watch your camera while going down the road, you will have to wire the camera power source to an always on power source. I did that with my boyo and it works fine. if i wire it up using backkup lights and driving down road what happens when you hit the camara button in the menu? if i wire it your way, will not come on when i put vehicle in reverse will it? Quote Link to post Share on other sites
wgm5286 Posted April 5, 2008 Report Share Posted April 5, 2008 the reverse trigger wire on the d3 is what is to be hooked to the back up lights. When it gets a signal from the reverse lights it activates the d3 reverse mode. this does turn on the camera if the power is also taken from the back up lights. But if wired that way, the camera will only have power if in reverse. If you want to use the camera any other time, you have to give it power from a source that is always on in the cars run mode. Quote Link to post Share on other sites
mrgoodbar67 Posted April 6, 2008 Report Share Posted April 6, 2008 so......if i connect the d3's reverse wire to the back up lights, and connect the power on the cam to a 12v acc......i will be able to have the cam come on in revers automatically AND look at it while driving down the road to check on my hitch? Quote Link to post Share on other sites
installermarc Posted April 6, 2008 Report Share Posted April 6, 2008 El-Correcto! Quote Link to post Share on other sites
bbyers Posted April 6, 2008 Author Report Share Posted April 6, 2008 so there is 2 wires for power? i thought that the only power wire was the one from the backup lights so to make sure i understand this right, you have a wire that goes to backup lights also a wire that goes to 12v source that is only activated when the car is running, and a video wire from camara to back of HD, and a ground, total of 4 wires to be hooked up? Quote Link to post Share on other sites
cntrylvr79 Posted April 6, 2008 Report Share Posted April 6, 2008 That would be correct. 1. Reverse wire goes to avic 2. Ignition power to camera 3. ground to camera 4. video wire from camera to avic. Quote Link to post Share on other sites
bbyers Posted April 6, 2008 Author Report Share Posted April 6, 2008 That would be correct. 1. Reverse wire goes to avic 2. Ignition power to camera 3. ground to camera 4. video wire from camera to avic. with this setup the camara will work when car is in reverse,but turn off when backup lights go out (put car into drive) and when i go to rear view option in the HD, if i want to check out my trailer while driving down interstate.......right? Quote Link to post Share on other sites
cntrylvr79 Posted April 6, 2008 Report Share Posted April 6, 2008 The camera will work when you back up and if you want to check on a trailer while going forward. Quote Link to post Share on other sites
