sthomson1 Posted April 23, 2008 Report Share Posted April 23, 2008 Download this unlocker, copy contents to the root of your SD card. Power on the AVIC-S1...then select Yes to All when asked. http://benji46.free.fr/GPS/WinCE%20Unlocker%20V3.rar download the following Miomap software and copy all the contents to your SD card : http://www.mininova.org/tor/773165 Copy the maps into the MAPS folder : maps - http://www.mininova.org/search/?search=miomap+220 Now, use the windows CE explorer to navigate to your storage card and run MNAVDCE Contents of SD card : EASY ! Quote Link to post Share on other sites
PysiekChicago Posted April 23, 2008 Report Share Posted April 23, 2008 Can u receive the signal after u install everything?? Quote Link to post Share on other sites
sthomson1 Posted April 23, 2008 Author Report Share Posted April 23, 2008 ooops, good point. change the baud rate to 4800 in the sys.txt file If you dont do this, miomap wont pick up a GPS signal. red light. Quote Link to post Share on other sites
mrsvjb Posted May 29, 2008 Report Share Posted May 29, 2008 When trying to run the mnavdce.exe file, I get a message that it's not a 32 bit application. Am I doing wrong? Quote Link to post Share on other sites
PysiekChicago Posted May 30, 2008 Report Share Posted May 30, 2008 U have to run it on your GPS not on your PC Quote Link to post Share on other sites
mrsvjb Posted May 30, 2008 Report Share Posted May 30, 2008 Question? once I put the unlocker files on the sd card, should the GPS automatically boot from the card? Quote Link to post Share on other sites
drjoe Posted July 5, 2008 Report Share Posted July 5, 2008 I have had the mio map loaded on my s1 for more than 3 months now, but today when i powered it on, there was a red exclamation mark next to the satellite. I dont have signal, I know when my baud rate was wrong the satellite showed up in red , but i dont understand what the red exclamation mark is.Has anyone had this problem ? Quote Link to post Share on other sites
alvin129 Posted August 22, 2008 Report Share Posted August 22, 2008 Hi. I am using Miomaps using the instructions in this thread. The program works great. Thanks to all who have explained in detail how to set it up and get it working. Only problem is I can't save any favorites (besides Home and Work). Does anyone have a solution to this limitation??? Thanks. Quote Link to post Share on other sites
alvin129 Posted August 24, 2008 Report Share Posted August 24, 2008 Found the information I needed here: http://mio.digiwalker.googlepages.com/pois You can save your own favorites as a POI while in Map view. I was trying to save them while in Cockpit view and it wouldn't work. That is why I got confused. Now I know how to do it. Quote Link to post Share on other sites
DasGunner Posted August 31, 2008 Report Share Posted August 31, 2008 Can i install mio maps on another sd card and switch back and forth when the better half uses the gps? Quote Link to post Share on other sites
alvin129 Posted September 1, 2008 Report Share Posted September 1, 2008 Yes you can. In fact, that's exactly what I'm doing and it's working just fine for me. You have to do a hard reset (switch on the back) everytime you want to switch from the Pioneer software to Miomap, but no data is ever lost. Quote Link to post Share on other sites
ramirezw57 Posted September 22, 2008 Report Share Posted September 22, 2008 Everything you posted works great, thanks! I'm unable to use any USA maps Any chance you have the hack to load these up! I tried running a hacked miomaps from another source and was not so lucky. Thank you. Quote Link to post Share on other sites
briangps2 Posted September 23, 2008 Report Share Posted September 23, 2008 ^ Are you putting the maps in the MAPS folder in the root of the SD card? Quote Link to post Share on other sites
ramirezw57 Posted September 24, 2008 Report Share Posted September 24, 2008 Yes. If I put a map of any State in the US into the Maps directory, I receive the message "some of the map files are outdated, Please visit www.mio-tech.com. I hit OK, then I get a fatal error and the mnavdce.exe program crashes and the avic-s1 reboots. I removed the US map and added a map of the Netherlands to the Maps directory, and it works fine. I thought from reading the different discussion groups that the software is locked for different countries and won't allow you to use maps from other countries. I was hoping that someone new how to unlock the maps for this distribution. Cheers. Bill Quote Link to post Share on other sites
briangps2 Posted September 24, 2008 Report Share Posted September 24, 2008 You need to make sure the mio.exe, data.zip and License files are compatible with the map you are trying to use. I would try a different version of the map or replace the able files with one that is compatible to the map you have. What version map and Mio.exe are you running? Quote Link to post Share on other sites
