mil0881 Posted May 18, 2008 Report Share Posted May 18, 2008 Hi Everyone I just got my z2 for 24 hours now and I have been playing with the options and I think I am getting confused and overwhelmed. I did the search and didn't get any answers, just dead topics with no answers anyway I have 2 questions 1- Can you rename the 4 My favorites folder under My mix? 2- I am parked and I switch from watching dvd to listen to music from the hard drive the volume is really loud any way to make them the same? Thanks for any help Quote Link to post Share on other sites
whtcrxghst Posted May 18, 2008 Report Share Posted May 18, 2008 1. No 2. Go in and play with the SLA in the sound settings on each source until they are all about the same volume Quote Link to post Share on other sites
mil0881 Posted May 18, 2008 Author Report Share Posted May 18, 2008 1. No2. Go in and play with the SLA in the sound settings on each source until they are all about the same volume Thanks for the help Quote Link to post Share on other sites
mil0881 Posted May 19, 2008 Author Report Share Posted May 19, 2008 2. Go in and play with the SLA in the sound settings on each source until they are all about the same volume Hi whtcrxghst I went in the volume settings and the only things I can control guidance voice, Beep, Phone ring and caller. Where did I go wrong? Thanks Quote Link to post Share on other sites
big-fokker Posted May 19, 2008 Report Share Posted May 19, 2008 Here you go, from page 151 in the manual: <<<<<<< Adjusting source levels Source Level (source level adjustment) lets you adjust the volume level of each source to prevent radical changes in volume when switching between sources. ❒ Settings are based on the FM tuner volume level, which remains unchanged. 1 Compare the FM tuner volume level with the level of the source you wish to adjust. 2 Touch [source Level] in the Audio Settings menu. 3 Touch [+] or [–] to adjust the source volume. +8 to –8 is displayed as the source volume is increased or decreased. Sources are set to same source level adjustment volume automatically. • CD and ROM (MP3) • XM and SIRIUS • EXT 1 and EXT 2 • AUX and AV INPUT >>>>> In a nutshell, hit A/V Settings, make sure you're on the Audio Settings tab, and then look for Source Level. Hit that and adjust up or down Quote Link to post Share on other sites
mil0881 Posted May 19, 2008 Author Report Share Posted May 19, 2008 Here you go, from page 151 in the manual:<<<<<<< Adjusting source levels Source Level (source level adjustment) lets you adjust the volume level of each source to prevent radical changes in volume when switching between sources. ❒ Settings are based on the FM tuner volume level, which remains unchanged. 1 Compare the FM tuner volume level with the level of the source you wish to adjust. 2 Touch [source Level] in the Audio Settings menu. 3 Touch [+] or [–] to adjust the source volume. +8 to –8 is displayed as the source volume is increased or decreased. Sources are set to same source level adjustment volume automatically. • CD and ROM (MP3) • XM and SIRIUS • EXT 1 and EXT 2 • AUX and AV INPUT >>>>> In a nutshell, hit A/V Settings, make sure you're on the Audio Settings tab, and then look for Source Level. Hit that and adjust up or down Thanks big-fokker It was better. Quote Link to post Share on other sites
