jwsievers Posted August 15, 2006 Report Share Posted August 15, 2006 I have a 2006 Trailblazer LT and I am curious if the AVIC-Z1 will fit in it. Also does the navigation require nav disks or is it all stored on the harddrive? Quote Link to post Share on other sites
Emay Posted August 16, 2006 Report Share Posted August 16, 2006 no nav discs required, Nav runs via the HDD. As to the trail blazer fit, I don't know that answer, but I bet you can find that out on the crutchfield web site. Quote Link to post Share on other sites
keithss Posted August 16, 2006 Report Share Posted August 16, 2006 yes it will fit. i have one in mine. Keith Quote Link to post Share on other sites
jwsievers Posted August 16, 2006 Author Report Share Posted August 16, 2006 do you have any pictures? Also any suggestions when installing to the trailblazer? What fitment kit did you use? Quote Link to post Share on other sites
cntrylvr79 Posted August 17, 2006 Report Share Posted August 17, 2006 To make the z1 fit in an 05 You have to cut out some plastic support for the back of the stock radio. As for the kit you can get a metra 99-3301 and just use the side brackets. I've done this several times in Trailblazers up to 05. From what I've seen of the 06 I don't see it bing much different. Quote Link to post Share on other sites
keithss Posted August 17, 2006 Report Share Posted August 17, 2006 or a metra 99-2003 Keith Quote Link to post Share on other sites
cntrylvr79 Posted August 18, 2006 Report Share Posted August 18, 2006 I've tried the 2003 kit, it never worked properly for me, but then again that was in older trailblazers. Maybe the new one is different. Quote Link to post Share on other sites
