AmarilloSD Posted June 15, 2008 Report Share Posted June 15, 2008 My F90BT isn't installed yet so I cannot currently speak about the operation first hand, but I found some information about voice navigation I thought might be helpful. Online Operation manual: p146 Basics of Voice Operation Your Pioneer navigation system uses the latest in voice recognition technology. You can use voice commands to operate many of its functions. This chapter describes where you can use voice commands, and also what commands the system accepts. Flow of voice operation You can start voice operation any time even when the map screen is displayed or audio is operating. (Some operations are not available.) The basic steps of voice operations are as follows. 1 Switch the screen to map screen or AV operation screen. = For details concerning operations, refer to Screen switching overview on page 18. 2 Press MULTI-CONTROL to activate voice operations. 3 Speak a command into the microphone after the beep. 4 When the command is recognized, the navigation system displays next options on the screen, and pronounces it in some cases. 5 Repeat previous step as necessary. 6 The requested operation will be carried out. p The voice operation may not be operable for a minute after the navigation system has booted p147 Starting voice operation % Press MULTI-CONTROL on map screen or the AV operation screen. The voice operation screen appears. If you lose your way... You can listen to the brief operating instruction by touching . To cancel voice operation You can cancel the voice operation feature at any time by saying “Cancelâ€. After you cancel voice operations, the display returns to the screen displayed before the voice operation screen appeared. p You can also cancel voice operation if you touch on the voice operation screen, or press MENU button or MAP button. Link to post Share on other sites
