Cesarr2006 Posted June 21, 2008 Report Share Posted June 21, 2008 Ok i bought my D3 a few months ago it was working fine i did the bypass and everything was going great. Yesterday i tried to search for a nearby starbucks and noticed all my search buttons were not working. I couldnt select any of them. I thought maybe there was something wrong with the bypass so opened it up and was checking the wiring nothing disconnected or anything. I decided to check it later and as i put it back into its place it just shut off no sound no lights nothing what so ever I need help please!!!! Quote Link to post Share on other sites
HiFiSi Posted June 21, 2008 Report Share Posted June 21, 2008 Either you blew the radio fuse or knocked a wire loose. Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted June 21, 2008 Report Share Posted June 21, 2008 Ok i bought my D3 a few months ago it was working fine i did the bypass and everything was going great. Yesterday i tried to search for a nearby starbucks and noticed all my search buttons were not working. I couldnt select any of them. I thought maybe there was something wrong with the bypass so opened it up and was checking the wiring nothing disconnected or anything. I decided to check it later and as i put it back into its place it just shut off no sound no lights nothing what so ever I need help please!!!! did you have to force it bak in place? it sounds like a pinched wire. take it out, check your connections, make sure its all good and check the fuse on the bak of the unit too. Quote Link to post Share on other sites
Cesarr2006 Posted June 22, 2008 Author Report Share Posted June 22, 2008 Yeah i did i kinda forced it in there. I checked the fuse in the back and one that controls the stereo in the fuse box below and they were both ok. I read yesterday to check all the fuses and i havent done that yet. What did you mean by a pinched wire? do you think something could have happened to it internally? I didnt bang it in or anything not i just gave it a little push. Quote Link to post Share on other sites
Guz Posted June 22, 2008 Report Share Posted June 22, 2008 Ok i bought my D3 a few months ago it was working fine i did the bypass and everything was going great. Yesterday i tried to search for a nearby starbucks and noticed all my search buttons were not working. I couldnt select any of them. I thought maybe there was something wrong with the bypass so opened it up and was checking the wiring nothing disconnected or anything. I decided to check it later and as i put it back into its place it just shut off no sound no lights nothing what so ever I need help please!!!! First thing you need to do is get a circuit tester and verify that power is getting to your D3 and check the fuse. It sounds to me that you either blew a fuse or disconnected a cable. Let me know the results. If still you have not figured out the problem, let me know and we will try something else. Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted June 22, 2008 Report Share Posted June 22, 2008 Yeah i did i kinda forced it in there. I checked the fuse in the back and one that controls the stereo in the fuse box below and they were both ok. I read yesterday to check all the fuses and i havent done that yet. What did you mean by a pinched wire? do you think something could have happened to it internally? I didnt bang it in or anything not i just gave it a little push. a pinched wire is where it gets caught between something and either causes a break in the wire or stops the current completely. it happened to me back when i did my first stereo install. one example would be if your yellow wire (constant+) or your red wire (12vpower) got pinched against a metal surface and is causing a short. check every wire out. Quote Link to post Share on other sites
Cesarr2006 Posted June 25, 2008 Author Report Share Posted June 25, 2008 THANKS FOR ALL THE HELP!!!!!!! It was just a fuse thank god i was thinking i had to replace it all....but thanks for all the helpto all u guys Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted June 25, 2008 Report Share Posted June 25, 2008 THANKS FOR ALL THE HELP!!!!!!! It was just a fuse thank god i was thinking i had to replace it all....but thanks for all the helpto all u guys worst feeling in the world.....go in such a panic to only find out it was a blown fuse. well glad to hear everything turned out good. Quote Link to post Share on other sites
Guz Posted June 25, 2008 Report Share Posted June 25, 2008 THANKS FOR ALL THE HELP!!!!!!! It was just a fuse thank god i was thinking i had to replace it all....but thanks for all the helpto all u guys Glad to hear you are good to go. We all knew it was something along those lines. Quote Link to post Share on other sites
