Z2 rear view is not available. wiring or settings?
  • 4 weeks later...
hi,
my camera is working on reverse but when I choose the Rear View I only see gray box on 3/4 screen. is this a wiring problem or setting that I have to adjust?
thank you
Hmm does it work in the split screen view in the Map view settings. Ie half nav half rear view? Hit the Map button to change the view to see if that works. GC
  • 2 weeks later...
The problem is that the installer or whomever hooked up your back-up camera used the reverse power that switches the nav to view the back-up camera, for the power source of the camera. When you put the vehicle in reverse, the camera has power. When you change map view to rear view the camera has no power because your not in reverse. hook the camera power up to acc 12v. I've had to rewire a few that were hooked up that way. You might think that it is not good for the camera to have power whenever the key is on, but I've had no come backs for camera failures for that reason.
