countdown Posted August 23, 2006 Report Share Posted August 23, 2006 Just installed my AVIC-D2 and GEX-P10XMT XM tuner and activated service for both XM and Navtraffic. Navtraffic works just fine but no audio from any of the XM channels. I am able to scroll through all the channels, again no sound. Everything else on the D2 works- FM, CD, Navi. IP Bus cable was plugged in. I called XM to send and resend the signal 4 times already. Anyone have any idea what the problem is? Thanks! Quote Link to post Share on other sites
cntrylvr79 Posted August 23, 2006 Report Share Posted August 23, 2006 Is the pbus cable plugged in to the bllue port or the black port of the xm tuner. It should be plugged into the black port of the xm tuner. Quote Link to post Share on other sites
countdown Posted August 24, 2006 Author Report Share Posted August 24, 2006 [quote name="cntrylvr79"]Is the pbus cable plugged in to the bllue port or the black port of the xm tuner. It should be plugged into the black port of the xm tuner.[/quote] That was exactly it. Thanks a bunch. Quote Link to post Share on other sites
daniel1 Posted November 5, 2007 Report Share Posted November 5, 2007 Thanx for posting this; I HAD the exact same problem, I say "had" because after reading this I double checked the work the installers did and moved the plug and now it works perfect. I am a little pissed off that the "professional" installers screwed up though. Quote Link to post Share on other sites
