kc_scooter Posted July 13, 2008 Report Share Posted July 13, 2008 Since Subaru uses a weird design where the body of the radio is a standard double din but the faceplate is wider, a kit from Scosche is needed to fill in the gaps around the factory trim panel. The bad thing about the Scosche trim panel though is it sticks out so far it makes it hard to use the control knob. Overall am pleased although am suffering through some of the issues that have already been discussed; iPod slow to sync, screen tends to wash out in daylight, etc. Quote Link to post Share on other sites
916Kev Posted July 14, 2008 Report Share Posted July 14, 2008 Looks pretty good. Congrats! Quote Link to post Share on other sites
Julius Posted July 14, 2008 Report Share Posted July 14, 2008 Good Job! Looks Goods! Now you need the update to fix the issues and you'll be set. Quote Link to post Share on other sites
UnReaL Posted July 14, 2008 Report Share Posted July 14, 2008 I just put the D3 in my 08 Impreza and I don't like that it is not flush also.... however, the scosche kit looks much better than the metra kit. I'll post pictures later. Quote Link to post Share on other sites
blindmind3 Posted July 14, 2008 Report Share Posted July 14, 2008 I just put the D3 in my 08 Impreza and I don't like that it is not flush also.... however, the scosche kit looks much better than the metra kit. I'll post pictures later. did you hook up the VSS wire? Where did you find it? I have an 08 impreza Outback Sport with an f90bt installed. Quote Link to post Share on other sites
ballsie Posted July 16, 2008 Report Share Posted July 16, 2008 Have you guys tried using some small spacers / washers before you place the headunit with the metra / scosche mount against the dashboard? I'm sure the mouting screws are long enough to cope with this. Would that not bring the headunit out far enough to avoid the problems you mentioned with it not being flush? Cheers. Quote Link to post Share on other sites
kc_scooter Posted July 16, 2008 Author Report Share Posted July 16, 2008 That's how the Scosche faceplate fits, it doesn't have anything to do with the mounting brackets. I've ordered a different trim panel from Subaru of Japan so I can get rid of the Scosche faceplate, I'll post some pictures when it's done. Quote Link to post Share on other sites
ballsie Posted July 16, 2008 Report Share Posted July 16, 2008 do you have a part number for the subaru part - i'd be very interested! Quote Link to post Share on other sites
ballsie Posted July 16, 2008 Report Share Posted July 16, 2008 Don't worry about it now - got one. Iain Litchfield, the Subaru guru in the UK has hooked me up For reference folks, I think it's about $70 in the US and just under £40 in the UK. Quote Link to post Share on other sites
kc_scooter Posted July 17, 2008 Author Report Share Posted July 17, 2008 Here's a picture with the new trim panel from Subaru. Much better than having to use the Scosche kit. Theres a slight gap between the trim panel and the head unit but not too bad. With the factory mounting brackets it still will be recessed so I've used some washers to shim it out. Quote Link to post Share on other sites
Julius Posted July 17, 2008 Report Share Posted July 17, 2008 That looks much better.Looks like the color matches perfectly. Quote Link to post Share on other sites
NickCat Posted July 17, 2008 Report Share Posted July 17, 2008 Very nice install... I used the same audio bezel from Subaru for mine. Looks significantly better overall. I just wish that Pioneer hadn't made the face of the unit a bit smaller than double din in the first place though without providing some sort of trim ring to flush it back out. I will have to try using some washers as you did to space mine a bit back towards the bezel. Are you a member of NASIOC.com? I'm Nick, the owner of the site. I've had an ongoing discussion about the unit and my install and issues thus far. http://forums.nasioc.com/forums/showthr ... ?t=1513622 I'm just waiting patiently at this point for the firmware updates as everyone else is. Quote Link to post Share on other sites
unrequited Posted July 17, 2008 Report Share Posted July 17, 2008 Awesome Nick... <3 NASIOC. I posted my 2006 STi install here: http://avic411.com/forum/viewtopic.php?t=16358 I'll bump that thread up! Quote Link to post Share on other sites
ballsie Posted July 21, 2008 Report Share Posted July 21, 2008 Hi Guys, Where have you all decided to hide the GPS antenna? I have the UK version, so no XM to try to hide too. Cheers, Alan Quote Link to post Share on other sites
unrequited Posted July 21, 2008 Report Share Posted July 21, 2008 Right under the clock plastic. Full reception, and even in New York City in Times Square I haven't had GPS reception problems. Quote Link to post Share on other sites
