radar007 Posted August 4, 2008 Report Share Posted August 4, 2008 I spotted an f-series bypass post dated-6/9. Is this the same way to bypass after the firmware update?? I have the f900 and it has been updated a week ago. Are there new bypass instructions ??. I am referring to not being able to watch the dvd while drivin at highway speeds. i am nu to the site so i will apologize to you vets i advance if this post is in the wrong place. please help Quote Link to post Share on other sites
HiFiSi Posted August 4, 2008 Report Share Posted August 4, 2008 It's the same. Nothing has changed. They would have to physically change the unit for the bypass to stop working, IIRC... and all that has been done to the new units is a firmware update. Quote Link to post Share on other sites
radar007 Posted August 7, 2008 Author Report Share Posted August 7, 2008 Thanx for your help. I f the bypass was not affected by the firmware update,is it poss. than what could be the reasons why my new 900 isnt working?? (I initially had a 700) I will just take it bak to the installer and have him look at it?? Thanx again Quote Link to post Share on other sites
KidFresh1 Posted June 4, 2009 Report Share Posted June 4, 2009 CAN YOU PLEASE HELP ME? I just purchased the F900 and it came with the 2.0 update. I want to be able to play DVD's for my son while driving. Can someone please give me some good directions on how to bypass this? Please help. Thanks, KidFresh1 Quote Link to post Share on other sites
dianebrat Posted June 4, 2009 Report Share Posted June 4, 2009 viewtopic.php?f=34&t=17013 viewtopic.php?f=34&t=15663 viewtopic.php?f=34&t=17715 Pick your poison Quote Link to post Share on other sites
KidFresh1 Posted June 5, 2009 Report Share Posted June 5, 2009 dianebrat or anyone else who can help. These updates for the bypass of the F900 to play DVD's while driving are all old instructions from 2007 and 2008. Does anyone have any recent instructions on how to bypass? I am just afraid that with the 2.0 update things might have changed. I also heard that once you do the bypass you will have issues with any updates that Pioneer provides. Is that true? Thanks so much if you guys can help. Quote Link to post Share on other sites
apathyps Posted June 5, 2009 Report Share Posted June 5, 2009 no, nothings changed. its 1 variable. just follow the directions. i wrote my own step-by step if you cant find any of the other numerous posts talking about how to bypass. viewtopic.php?f=34&t=15663&start=210 Quote Link to post Share on other sites
KidFresh1 Posted June 5, 2009 Report Share Posted June 5, 2009 Thanks for that info. But does anyone have instructions on how to do the bypass via hardware? I heard the software bypass eventually will ruin your system. Anyone have instructions on how to bypass the F900 to play DVD's via hardware? Thanks Quote Link to post Share on other sites
apathyps Posted June 5, 2009 Report Share Posted June 5, 2009 ruin your system? that is completely false. if you want the hardware bypass, just do some searching. its been answered a billion times. moev the mute wire from 4 to 1, or 1 to 4. cant remember. go search for 2 minutes and you'll find quite a few threads and hundreds of posts about it. Quote Link to post Share on other sites
KidFresh1 Posted June 5, 2009 Report Share Posted June 5, 2009 I found a thread. Is this correct? From WIRE SIDE of small white plug Mute wire (YEL/BLK) is in upper row, left pin Move this wire to lower row, 4th pin from the left (empty pin between 2 black wires) the pin directly below the mute wire does not work Ground YEL/BLK & LT GRN and you're good to go Quote Link to post Share on other sites
apathyps Posted June 5, 2009 Report Share Posted June 5, 2009 sounds about right, tho i didnt do the hardware bypass. software was much easier for me to do. couldnt be bothered pulling the unit out of the dash and splicing wires. the lt green to parking brake was enough for me. Quote Link to post Share on other sites
KidFresh1 Posted June 5, 2009 Report Share Posted June 5, 2009 Cool. Hopes this works. Quote Link to post Share on other sites
HAAK31 Posted June 8, 2009 Report Share Posted June 8, 2009 simply connect the handbrake wire to the black wire and everything works, easy as that! Quote Link to post Share on other sites
