karadio Posted August 23, 2008 Report Share Posted August 23, 2008 Trying to connect a Bell Blackberry 8830 to the F90BT. The search goes ok and it connects but then disconnects withing about 10secs and comes up connection terminated on the Blackberry. If I try to reconnect, it will fail. I have to delete the pairing from the F90 and the Blackberry and start from scratch. A hard reset to both machines as no effect. Any ideas? Quote Link to post Share on other sites
tacomaboy Posted August 25, 2008 Report Share Posted August 25, 2008 Trying to connect a Bell Blackberry 8830 to the F90BT. The search goes ok and it connects but then disconnects withing about 10secs and comes up connection terminated on the Blackberry. If I try to reconnect, it will fail. I have to delete the pairing from the F90 and the Blackberry and start from scratch. A hard reset to both machines as no effect. Any ideas? I get the same damn problem now with my 8330. Not sure why - it did not do this pre update. And for a while post update it worked great! (except when you disconnected, or let the other person hang up - it would hang). But now I get constant disconnects/reconnects.... gaaarrr Quote Link to post Share on other sites
lemonhead Posted August 26, 2008 Report Share Posted August 26, 2008 Getting the same thing with my 8830. Here's the weird thing...before I had put any of my contacts into a category, I had no connection problems (except for slow to connect on startup). Then I categorized some contacts and began getting the connection dropouts. I took out all categories, but now am still getting the problem. Ugh. Quote Link to post Share on other sites
chickon Posted August 26, 2008 Report Share Posted August 26, 2008 I found that your connection will be more stable if you let the phone to search and find the navigation. not the other way around. remember enter 1111 when the phone ask you to put in a code, anything else will not work. Quote Link to post Share on other sites
orgasm_donor Posted August 26, 2008 Report Share Posted August 26, 2008 I had the same problems with my 8130 Blackberry. For the first couple of days it would connect/terminate constantly which was annoying. I took my phone and did a complete back-up and applied the newest update on Blackberry's website. Well, turns out, that worked! For one week. Now its back to the same old crap. Not sure whether I should toss my phone out the window or take a hammer drill to my deck. Quote Link to post Share on other sites
lemonhead Posted August 26, 2008 Report Share Posted August 26, 2008 I had the same problems with my 8130 Blackberry. For the first couple of days it would connect/terminate constantly which was annoying. I took my phone and did a complete back-up and applied the newest update on Blackberry's website. Well, turns out, that worked! For one week. Now its back to the same old crap. Not sure whether I should toss my phone out the window or take a hammer drill to my deck. Hammer drill. It's not the phone's fault I'm sure of it. Quote Link to post Share on other sites
OneFast1 Posted August 27, 2008 Report Share Posted August 27, 2008 I have an F900 and had trouble with a Blackberry Curve and a Blackberry 8830. In both cases it would sync and connect and then drop the connection. I tried a co-workers 8830 and had no problem, tried another 8830 and had no problem. So what was wrong with my 8830? I had a lot of duplicate profiles in my address book. I cleared my address book, because that was the only thing that was different between my Blackberry and the other users Blackberry, it worked! I cleaned up the duplicate entries in my address book and the BT works well now. Quote Link to post Share on other sites
lemonhead Posted August 27, 2008 Report Share Posted August 27, 2008 I have an F900 and had trouble with a Blackberry Curve and a Blackberry 8830. In both cases it would sync and connect and then drop the connection. I tried a co-workers 8830 and had no problem, tried another 8830 and had no problem. So what was wrong with my 8830? I had a lot of duplicate profiles in my address book. I cleared my address book, because that was the only thing that was different between my Blackberry and the other users Blackberry, it worked! I cleaned up the duplicate entries in my address book and the BT works well now. Interesting. I had one double entry, I'll try it. Do you think its just exact duplicate entries, was it ok if you had one entry "Mike" and another "Mike Cell"? Quote Link to post Share on other sites
tacomaboy Posted August 27, 2008 Report Share Posted August 27, 2008 Well ring my bell it worked! I had one double entry. Removed the second one and shazam! Now fix the bootup and sluggishness for me hehe. Quote Link to post Share on other sites
lemonhead Posted August 28, 2008 Report Share Posted August 28, 2008 Well ring my bell it worked! I had one double entry. Removed the second one and shazam! Now fix the bootup and sluggishness for me hehe. No more lawsuit? Quote Link to post Share on other sites
tacomaboy Posted August 28, 2008 Report Share Posted August 28, 2008 Well ring my bell it worked! I had one double entry. Removed the second one and shazam! Now fix the bootup and sluggishness for me hehe. No more lawsuit? Well it does fix one major problem.... still.. was this a Pioneer defect or a Blackberry one. I think it was a Pioneer defect. It should not have happened, but I am very glad someone found the fix. Quote Link to post Share on other sites
kal9el Posted August 28, 2008 Report Share Posted August 28, 2008 i'm experiencing the same issues with my F90BT + blackberry 8310 curve. what do you guys mean by "double entry" or "duplicate profiles"? please clarify. thanks. Quote Link to post Share on other sites
tacomaboy Posted August 28, 2008 Report Share Posted August 28, 2008 i'm experiencing the same issues with my F90BT + blackberry 8310 curve. what do you guys mean by "double entry" or "duplicate profiles"? please clarify. thanks. Check your address book and make sure you don't have the same name in there twice. Quote Link to post Share on other sites
kal9el Posted August 28, 2008 Report Share Posted August 28, 2008 i dont have any duplicate entries. 310 unique entries, most of which have two or more numbers per entry (work, cell, home, etc). my address book syncs with my outlook contacts; i dont assume that to be an issue? it started out for the first week working fine. but now, it does the connect/disconnect thing... help! Quote Link to post Share on other sites
