leetcoder Posted August 30, 2008 Report Share Posted August 30, 2008 Here we go USA/Canada RedLight and Speedcam POI. Just download the zip extract it to the root of the SD Card and you should be able to feed it into your AVIC. Enjoy. This is based on POI-Factory POI. Thanks to VBLUE42 for the attachment. USACANADA_CamerasPOI.zip Quote Link to post Share on other sites
cigga24 Posted August 30, 2008 Report Share Posted August 30, 2008 Does this have the audio alerts or speed cam icons? Quote Link to post Share on other sites
danieldelgado29 Posted August 30, 2008 Report Share Posted August 30, 2008 I'm new to this site...What to you my root of the SD! if you could explain more that would be kool! Quote Link to post Share on other sites
leetcoder Posted August 31, 2008 Author Report Share Posted August 31, 2008 I'm new to this site...What to you my root of the SD! if you could explain more that would be kool! Extract it into your storage card root folder which means /Storage Card/ after extract your SD card should contain the folder "POI" and "usericon". Put your SD card into the Pioneer Unit .... go to manage poi you can change settings in there so that those poi can appear on map. Quote Link to post Share on other sites
leetcoder Posted August 31, 2008 Author Report Share Posted August 31, 2008 Does this have the audio alerts or speed cam icons? No our pioneer unit doesn't have the audio alert features for poi. Yes it have cams icon, just make sure you change the view options in Manage POI. If im correct, I believe its Settings-> Navi Settings->Visual->Manage POI Quote Link to post Share on other sites
VBLUE42 Posted September 2, 2008 Report Share Posted September 2, 2008 Ok so I have found what appears to be yet another bug in the F series OS. Not all of the POI icons will appear in the POI select screen when viewing. To test this make sure you have all of the speed/redlight cam POI's on your SD card. Then hit MENU, DESTINATION, POI. Be sure to hit POI and not USB/SD. In the list of all the POI's some of the POI's wont appear in the list. It is imperative that they show up in this list or they will not show on the map which will defeat the purpose of these POI's. All will appear on the SD card but not in the POI list. I have for instance CENTRAL US REDLIGHT CAMERA 1 and 3 but 2 does not appear. If any of you are getting all of them to show under the POI menu let me know. Quote Link to post Share on other sites
Peleg Posted September 3, 2008 Report Share Posted September 3, 2008 So I followed the instructions, but it doesn't seem like you can download ALL THE DATA into the Pioneer. So far I'm only able to save each entry at a time......nobody is going to spend time doing that........ There has to be a way to download everything at once and be done with this. Quote Link to post Share on other sites
VBLUE42 Posted September 3, 2008 Report Share Posted September 3, 2008 Which instructions did you follow? Quote Link to post Share on other sites
cigga24 Posted September 3, 2008 Report Share Posted September 3, 2008 I think mine are there. but it will only allow the poi near my position. so east 2 may not show up cause its no where near me. when I first started car with sd in it ran really sluggish so I took it out then put it in and it ran fine since. I keep sd in now. Quote Link to post Share on other sites
Peleg Posted September 3, 2008 Report Share Posted September 3, 2008 Which instructions did you follow? From one of the threads here. My Garmin Nuvi that costs $250 can do it in 2 minutes and retain 4000 POI's into its internal harddrive. It's just sad an $1100 unit can't. I will be calling Pioneer about this. And also this stupid limitation of 300 POI's, what's that all about. Quote Link to post Share on other sites
VBLUE42 Posted September 3, 2008 Report Share Posted September 3, 2008 Post here what they tell you. Dont expect to hear what you want to hear. Quote Link to post Share on other sites
Peleg Posted September 3, 2008 Report Share Posted September 3, 2008 Post here what they tell you. Dont expect to hear what you want to hear. Called them at lunch: So the Pioneer doesn't have an internal HDD, I didn't know that. The rep said that you can't save anything to the unit and if you pull the SD card out, the POI's are gone. WOW, WHAT A GREAT INVENTION! An $1100 unit that can't save POI's...... I advised him that Pioneer got their work cut out for them because this unit needs a LOT of work. I told him about the noisey fan in the back and he said that's normal for this time of year. He then told me: "Well maybe you're not ready for an in dash unit" I'm going to test the hell out of this unit this weekend, if I'm still feeling the same as I do now, this unit is going back and I'm done with Pioneer for good. Quote Link to post Share on other sites
Stephanie Posted September 3, 2008 Report Share Posted September 3, 2008 The F-series do not have an internal hard drive but they do have a 2GB flash drive which more or less acts like a hard drive. It has roughly 1.6GB used, so there's about 400MB available - although I wouldn't want to fill it right up, just in case. It might need the extra space for other things, like running a firmware upgrade etc. You could probably use windows mode / testmode to put poi's onto the flash drive. There's a POI directory in the iGo directory: \My Flash Drive\APL2\iGo\Content\POI I haven't gotten around to messing with POIs yet, but it's further down on my to-do list. It's unacceptable (to me) that I'd need to leave a card in there for custom POIs. Edited to add: re. the fan noise - I know every situation is different, but in my case I cannot hear the fan at all unless the car is turned off (with the nav unit on) and there is no music playing. Only then, can I hear the fan. If you can hear the fan over the sound of the car engine and over the music, then the only thing I can suggest is this: Make very sure that there is nothing blocking the fan, behind the nav unit. They make a point of this in the installation manual - the fan exhaust must not be obstructed. If the fan's obstructed, it will spin too fast / work too hard, and that will contribute to louder than usual fan noise. Quote Link to post Share on other sites
HackZ Posted September 4, 2008 Report Share Posted September 4, 2008 Can some one please write a Step By Step on how to get the POI working off the SD. I took them from the Zip. and then got the POI and other folder to the SD went to the car and then to the main menu. then went to settings and navi settings then visual and manage POI then I am lost I made a new group and all that but then what there nothing that allows ne to add from the SD. and when I got to mean menu and then destination then SD all it says is Contacts and thats all. Ahhhhhhh Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted September 4, 2008 Report Share Posted September 4, 2008 He then told me: "Well maybe you're not ready for an in dash unit" That's good ol' Pioneer service for you. No respect for the customers that keep their shitty business going. If it wasn't for the update and hacks that this unit has I would be a DNX owner, especially if a rep said that to me. Quote Link to post Share on other sites
